Results 1 to 9 of 9
Reload Thread: Need help with my enclosure!!!
    BumpThat93's Avatar
    BumpThat93 is offline Biggie Smalls
    Nov 2003
    Philly
    35
    27
    Whats up everybody. I recently got rid of my 2 JL 12W3v2s after I blew them. I replaced them with 2 Pioneer Premier tsw2000spl subs. However, when we were putting the Pioneers in, we noticed that my sealed box did not have a center divider. When I went back to the shop that made my box, I was told that I didn't need a divider, but aren't I losing output? Don't get me wrong, these subs pound nicely, probably harder than my JLs did. I am also running on my stock battery, with a capacitor. I was thinking about replacing the stock battery with a red top optima. Will I get an increase in sub volume after I get the better battery? I know this is all kid stuff to you pros, but please help me. The shop also told me that I should just get a 12W7, but I know there are many other possibilities. Do you have any suggestions as to setups I could go with that would be comparable with a W7, or do you think I would be fine with the Pioneers I have.
    P.S. - I am running a JL 500/1 amp
    Thanks everyone,
    Drew
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Re: Need help with my enclosure!!!
    The shop offered that because it is there best sub they have, and most exspensive! There just tryin to make a sale.
    You do not NEED a divider but it wont hurt to have seperate chambers. Many people belive if you are running your subs in stereo with tho channels left and right. It will cause problems with cancelation and even possibly damage to your subs. So why not put a divider in.
    If you seriously are not happy with the pioneers and have the money for the JL buy it. If you want to save some money but have a similar product there are many options.
    What music do you listen to?? do you want more SQ or SPL or in between "SQL". Let us know and we can recommend a few brands that will meet your needs.
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    i've found that every sub stage i've worked with that was sealed in a shared chamber had problems with cancellation and eventually injurying the woofers (think of a tug of war). Also... noticed much better performance if the subs are wired together-mono in a shared chamber.
    Sorry, dont have anyhting more to go on then my own experience.
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    If the subs are receiving the same signal there will not be a cancellation problem with the shared chamber. If they are wired in stereo then you might have problems. The generally best solution is to wire them to the same channel as suggested above and that solves the cancellation problems with a single chamber.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    BumpThat93's Avatar
    Nov 2003
    Philly
    35
    27
    trigger, i mainly listen to hip hop and rap. i liked the sound quality that my JLs brought, but my pioneers seem to get louder, but the sound quality is noticably lower. I am looking for a sub to have adequate sound quality, but to scare me when it hits. My pioneers do their job for now, I mean they pound, but part of me still wants to upgrade or change brands. Let me know what you think, I appreciate it a lot. Thanks. Also thanks everybody else who responded so far.
    Drew
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    Adire Audio Brahama. Biggie would approve !
    BumpThat93's Avatar
    Nov 2003
    Philly
    35
    27
    c, i have seen a lot of buzz about the adires. how much do they usually cost? what kind of amp should i run them from? i have a JL 500/1 now, would that do the job? any other info you want to include is cool too. thanks man.
    drew
    tRiGgEr's Avatar
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    With only 500 watts to work with the JL would be number 1 option if money is no issue.
    Cheaper route RE SE, Adire <---- may be a little under kill with the power???, ID, Infinity... Even Kicker has some good products for cheap.
    But for your best options JL W7, or W6v2. <---- amazing products but costly.
  9. #9
    tRiGgEr's Avatar
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Also the new Fosgate T1's are sick ars subs.
  1. What's the difference in sound?
    By bonbon989 in forum Enclosure Design & Construction Help
    Last Post: 07-07-2004, 05:00 PM
  2. Is This Sub Enclosure Good For My Explorer???
    By PeteNYC in forum General Discussion
    Last Post: 06-30-2004, 10:24 PM
  3. '96 Town Car Stock Subwoofer Enclosure
    By Tyler Cory in forum Enclosure Design & Construction Help
    Last Post: 06-02-2004, 09:59 PM
  4. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
