+ Reply to Thread
Results 1 to 14 of 14
Reload Thread: New Box Build. Trying to squeeze (4) 12" in my 300
    znewberry's Avatar
    znewberry is offline Member
    Jan 2018
    Illinois
    114
    40 Post(s)
    I like to push the limits. Im absolutley satisfied with my (2) 12" setup (pic below). I want to keep the same style box **maybe with aero port this time** (port in, fire in with 2 subs) and add 2 more 12" to the enclosure firing either up into trunk lid or out into trunk. Is this possible? rough sketch below to demonstrate.
    One or the other orange or blue.
    stays same, maybe do areo port instead
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now AKA MR. 2OHM
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    Re: New Box Build. Trying to squeeze (4) 12" in my 300
    what subs are those? u won't have enough air space for 4 12's, maybe not in trunk diff not in same box unless it's 4cf per sub now..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
    2 ohms rule
    znewberry's Avatar
    Jan 2018
    Illinois
    114
    40 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    straight from the owner: 1.75-2.0 per is pretty ideal on size.. as little as 1.5 and as much as 2.25 is acceptable with recommended power. Anything significantly over power closer to 1.75 per
    they are rival 12"
    znewberry's Avatar
    Jan 2018
    Illinois
    114
    40 Post(s)
    1.75 x 4 is 7 cubes... I feel a challenge!
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    Quote Originally Posted by znewberry View Post
    thats right i remember now.. box looks good.. i just meant won't fit in same box.. if u can do a 7 cf ad box i guess u can make it work but someone will tell u it's not good to have subs facing different directions.. u be better off play them few months and get some 2 15's, maybe same size box but at least subs facing same way..
    2 ohms rule
    znewberry's Avatar
    Jan 2018
    Illinois
    114
    40 Post(s)
    I really would like two 15s . have u ever seen two of em in a 300 ported and firing in without a wall?! I hated how the car sounds with subs firing to rear, trunk neeeds a **** ton of sound dampening.
    outer dimension for height is like 15" tight firing in
    I can fit 3 12's firing in all same direction , port size will be iffy
    these arent flexin but look at his box https://www.youtube.com/watch?v=uvtidt6OVFg
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    lol thats the subs i had last, had orion hp's for 8 yrs or so.. guy bought my whole system and i got to shopping and my audio addiction kicked back in.. one those subs gotta tell ya those would be louder firing rear or maybe that trunk ain't sealed good, my single pioneer 12 moved my mirror much more than his was.. my 04 grandprix rattles like h man i only have 1 sheet of mat and some crap i'll have to rip out , i gotta get some gp stfu 250 mil, i have 1 sheet if i have 3 back there it would help, u should order the 5 sheets $100 see how subs sound rear u may gain 3db firing rear and not need more subs, i think i have 15.75 or so in height in trunk it would be hard to get them in and out but if u find a 15 thats say 15.5" high and u can fit that just screw sub to to and bottom board make box exact height of sub.. at least try the mat though..
    2 ohms rule
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    here's my trunk with 1 pioneer 12.. https://www.youtube.com/watch?v=rTcgVGvuFX8
    2 ohms rule
  9. #9
    Joker5381's Avatar
    Joker5381 is offline Junior Member
    Feb 2018
    NC
    1 Post(s)
    Not sure this would work but just a thought if you have the cu ft needed for the speakers and you could make it fit. Maybe think of sealed enclosure unless you could port through the rear deck. Just an idea I was thinking of to get all the woofers to fire in same directions. Picture attached of an example of what I mean by "W" style box I'm referring to.
  10. #10
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    13,544
    39 Post(s)
    5715 Post(s)
    Showoff.....
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  11. #11
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    Showoff.....
    dude has 2 12's in nicer box than mine how am i "showing off" with $80 SUB AT 2 OHMS?
    2 ohms rule
  12. #12
    Jul 2005
    WA
    13,544
    39 Post(s)
    5715 Post(s)
    Inserting your uploaded vid of your single 12 on this guys thread isn't showing off??? Then tell me what you call it..............going back to your old self I see...
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  13. #13
    Jan 2017
    NC
    5,340
    18
    27 Post(s)
    2129 Post(s)
    i call it showing him we all have rattles which is what we were talking about
    2 ohms rule
  14. #14
    Jul 2005
    WA
    13,544
    39 Post(s)
    5715 Post(s)
    Oh BS...
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
+ Reply to Thread
