+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 60
Reload Thread: Box design help 4 DD 9510gs
  1. #16
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,648
    24 Post(s)
    1926 Post(s)
    Re: Box design help 4 DD 9510gs
    Quote Originally Posted by Papermaker85 View Post
    I never liked how they sound in small boxes I've heard of 9510 and 1.75 and that b**** slammed on lows in 1.5 and it was way to over damped but I'd be silly to argue with you..
    I’m not running any big systems atm... but I did order a new dbm2 meter tonight so I may put something back together soon ...to play with the meter
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  2. #17
    shredder2's Avatar
    shredder2 is online now CarAudio.com Elite
    Nov 2017
    Phoenix Az
    1,507
    42 Post(s)
    602 Post(s)
    That's roughly just under 9.5 gross cu ft. What do those require for airspace ported? @shredder2
    Even aeroported 6ft3 net will be a stretch... best I could come up with is 1.45ft3 per... 1 10" aero tuned to 34hz... and thats single baffled subs up/port back... Idk if they'll do ok in that airspace but you can draw it up if you want. I only accounted for subs, dowel bracing and port displacement... and really did it quick.
    So its not exact but in the neighborhood
    If the width can be increased to say... 36" or height a bit it'll be easier and able to be braced better with 45's as well as a double baffle.
    Then it'll be feasible to get 1.5ft3 per tune to 33hz and brace it properly, add 45's and a double baffle too.
    16x32x32 just seems too small to really do it right
  3. #18
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    Quote Originally Posted by Louisiana_CRX View Post
    Haven't ran a big system since 07 Maybe it's on now I'm tired of these love s*** talkers
  4. Thanks shredder2 thanked for this post
  5. #19
    Ispector's Avatar
    Ispector is offline Member
    Jan 2012
    San Antonio, TX
    125
    1 Post(s)
    46 Post(s)
    Quote Originally Posted by shredder2 View Post
    I will re measure and see what dimensions I can come up with. The hatch area is shaped like an upside down T it’s skinny between the strut towers and opens up to the back of the hatch.
  6. #20
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,276
    15
    39 Post(s)
    4245 Post(s)
    I have no idea why the tuning keeps going lower and lower. That will sound terrible. Stick with DD recommended volume and tuning for best results.
  7. #21
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,507
    42 Post(s)
    602 Post(s)
    Quote Originally Posted by Ispector View Post
    Does this look like it'll fit? This is around 6.1ft3 net around 33.5hz, shorten the port to 20" long and its around 6.2ft3 net at 35hz, It's double baffled, braced and 45'd.
    Just make sure there is sufficient clearance for the port to breathe.
    18" long is 36hz at 6.3ft3... as far as tuning goes it's easy and the explicit ultimate box app is really close to Winisd... that's 1.25 driver/bracing displacements btw (4 ea 4" 45's and 2 ea 1.5" dowels top to bottom)
  8. #22
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    The lowest I would tune is 35 other than that you're killing so much output with that drivers it's not even funny
  9. #23
    Ispector's Avatar
    Jan 2012
    San Antonio, TX
    125
    1 Post(s)
    46 Post(s)
    This could work if I can have the port on one of the 32” sides. I will get more measurements later today. DD has 1.25 cuft. for small box and 1.5 for large box on their website.
  10. #24
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,672
    29 Post(s)
    1489 Post(s)
    Pecan monies?
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
  11. #25
    kr15's Avatar
    Feb 2010
    California
    6,672
    29 Post(s)
    1489 Post(s)
    Id put the subs in no less than 1.5 per. And a tad more if possible. That 6.2cu at 35hz should slam
    Team Flex Issues
    JVF Customz
  12. #26
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,507
    42 Post(s)
    602 Post(s)
    You list your H x W x D.. and how you think the port should be oriented (maybe draw a pic?) and I'll see what I can come up with. Make sure the port has clearance for sure, about 5" minimum or it might change tuning... IDK what you got in mind so a drawing would probably be good.
  13. #27
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    Do 17. Problem solved
  14. #28
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,507
    42 Post(s)
    602 Post(s)
    If you got 36" width to play with then this might leave enough clearance to the tailgate if you have 32" available in depth. It's 5.84ft3 at 36hz subs up/port rear. I figured to raise the height 2" to 18' and find enough space in back for the port. Idk if this tune is what you want but I am practicing sketchup so here it is.
    That's 1.46ft3 per, common chamber
  15. #29
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    I really need to learn how to use SketchUp I'm so used to use an old can't think of the name a f****** program but where you can set you XYZ parameters writing lines of code. Schedule for some reason just irritates the s*** out of me
  16. #30
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    Autocad. Lol
+ Reply to Thread
