Results 1 to 14 of 14
Reload Thread: Nearly Ready to Fiberglass (Questions)
    idiot's Avatar
    idiot is offline Senior VIP Member
    Dec 2003
    Connecticut
    31
    378
    I’m in the stage of gathering materials to build my first sub enclosure using fiberglass (well, an MDF/fiberglass hybrid, actually). Here’s what I have picked up (all from Home Depot). Please let me know if something I should have is missing from the list.
    Fiberglass Resin (Bondo brand)
    Extra tubes of Hardener
    Fiberglass mat
    Crappy paintbrushes, of various sizes
    Latex gloves
    Painter’s tape
    Spray Adhesive
    Some really heavy plastic sheeting to lay across the car
    Firstly, Home Depot didn’t have any fiberglass cloth (only the mat). Am I correct in assuming that the only benefit of cloth is its ability (due to its reduced thickness) to mold to more delicate details? If so, it is not necessary in my application.
    I’m going to be glassing a vertical surface. I’ve read recommendations to apply a thin coat of Vaseline to the painter’s tape before applying the first layer of fiberglass, so that the mold would be easier to remove from the vehicle once it has set. However, I’ve also read that I should use some sort of aerosol glue to stick the cloth to the vertical surfaces before dabbing on the resin, in order to hold them in place. These two ideas seems slightly incompatible to me; I don’t understand how I could spray down the glue for the first layer of mat, after I had already rubbed Vaseline on the painter’s tape. What is the best way to go about these two things (that is, ensuring that I can remove the mold after the first few layers without risking harm to the box, and holding the cloth on the vertical surfaces securely, before the resin is applied)?
    This isn’t something that I’ll deal with until later, but how would I go about attaching a side of MDF to a partially made fiberglass enclosure? The front and top pieces for my box need to be MDF (as they are straight sides), while every other side needs to be contoured to some sort of curve (and therefore made with fiberglass). Would I simply use the resin/cloth mixture to make the connection between the two materials, or would I have to use screws or something like Liquid Nails in addition?
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    31
    15,596
    22
    Re: Nearly Ready to Fiberglass (Questions)
    i find the clothe is a lot easier to work with
    you can put some vaseline or something down, i would use just a little resin to get it to stick to the side
    the resin sticks to MDF
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
    btnhfan's Avatar
    btnhfan is offline Hail to the King Baby!!!!
    Jan 2004
    CT/ GA Tech, Atlanta
    31
    7,067
    your gonna wana put bondo or any body filler on the fiberglass afterwords
    Best receiver ever?
    I think so
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    mask, do you want to get high?
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Quote Originally Posted by supa_c
    Hell yeah, the fumes are the best part man
    5 % equipment
    90 % install
    5% beer
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    one thing u need but cannot by, is common sense. as far as it holding to the part your attaching the mat to....just hold it with one hand and drop a little resin on and go at it, it wont move. and theres no "vertical surface" as u can always turn the box and make that side flat and u wont need anything to hold it.
    idiot's Avatar
    Dec 2003
    Connecticut
    31
    378
    I forgot to put that on the list. But yea, I've got one.
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Quote Originally Posted by idiot
    Fiberglass mat
    Latex gloves
    Painter’s tape
    Spray Adhesive
    Gonna need some body filler to add to your list. And a bunch of sandpaper.
    Yeah you can do it with just mat. Although cloth does smooth around curves real nice
    When I'm doing vertical surfaces and need to use fleece. I put down a layer of tape. Then a layer of foil over the tape. Then I spray some adhesive down. I use elmers spray adhesive. It's crappy glue but holds long enough for this purpose Then put the fleece on. Then soak the fleece and add a couple layers of mat, Then boink out pops my panel
    Nope no liquid nails. Just resin and mat, it sticks real well to mdf by itself
    5 % equipment
    90 % install
    5% beer
  9. #9
    idiot's Avatar
    Dec 2003
    Connecticut
    31
    378
    Quote Originally Posted by saywhat?
    Many of the tutorials I've read say that it is better to stick all the cloth/mat to the area before applying resin, rather than sticking it piece by piece as one goes along, so that one can be sure that they will line up properly. So my intention was to first set up the pieces of mat over the area to be glassed, then mix the fiberglass and apply.
    In case I haven't explained it well, here are a few pictures from one of the tutorials.
  10. #10
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Quote Originally Posted by ramos
    This is the way I go about it. I do pretty much the same thing as your describing. I just don't use the vaseline. THe only time I use vaseline is when I'm copying a panel. I then use the vaseline directly on the panel. Then glass right on it.
    5 % equipment
    90 % install
    5% beer
  11. #11
    idiot's Avatar
    Dec 2003
    Connecticut
    31
    378
    So you’ve never had a problem removing the mold from the car, even without using something like Vaseline or WD-40? And does the layer of foil you place over the tape do anything other than give added protection against leaks?
  12. #12
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Nope, the tape keeps the resin from gettting through to the car. And the foil keeps everything from sticking. The foil is actually the mold release. Some of the foil will stick to the glass. But the glass won't stick to anything else, and you will be able to remove the mold from the foil.
    5 % equipment
    90 % install
    5% beer
  13. #13
    idiot's Avatar
    Dec 2003
    Connecticut
    31
    378
    Alright, I'll slap some foil down, in that case. Thanks.
  14. #14
    Hondaluv's Avatar
    Hondaluv is offline Member
    Mar 2004
    Grande Prairie, AB.
    35
    34
    If you have troubles laying cloth onto verticle parts you cannot tilt, slap a little resin on the part, stick the mat to it, and dab more resin in to soak, resin is relevently sticky, should be fine.
  1. Fiberglass.....how do you make a bottom?!?!
    By swimfreak26 in forum Enclosure Design & Construction Help
    Last Post: 08-17-2004, 12:52 AM
  2. A Couple of System Questions
    By LostCause in forum General Discussion
    Last Post: 04-23-2004, 07:41 PM
  3. ---READ---Something that would make fiberglass more fun for everyone!!
    By mayday0017 in forum Enclosure Design & Construction Help
    Last Post: 01-12-2004, 07:24 PM
  4. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
  5. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
