+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Need help with box for 1 American bass xfl 15
    Apr 2017
    Clinton NC
    93
    53 Post(s)
    Wasup guys I'm trying to figure a box for one xfl 15 I'm pretty sure there's been a thousand threads on aero ported boxes I've watched vids and threads but I really don't understand it anyways I'm going to be running a orion 1500 watt amps puts outs roughly 1700 watts at one ohm on the birth sheet. I used the calculator thing to get the port length my box will be 4 cf and I would like a tuning of 32 hz I've built 3 boxes before one of my boxes was for 6 soundqubed hds312s but it was a 4th order blowthrough so I'm not used to aeroported boxes mainly just square ports... On the calculater I will be using 1 6" diameter port and if the box is 4 cf and needs to be 32 hz it says that the length of the aero Port needs to be roughly 15 to 16 inches. Does that sound right to you guys? I don't want any port noise or anything like that and do you think a 4 cubic feet box tuned to 32 hz is right for a xfl 15? Any help would be appreciated sorry for the long post.
    shredder1's Avatar
    shredder1 is offline CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Re: Need help with box for 1 American bass xfl 15
    Looks good... I figure around 1200 or so after rise... that's how it models up anyways... Anyone else?.. I'm just an enthusiast that's tryin' to help... lol
    The Budget Beater Blazer Build... Lookin' for those Basshead Problems!
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    A 6" x 6" square port keeps the port velocities lower it appears... that might be your best bet... anyone?
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    8" aero looks like too much port... I've been told to keep the velocities at or near 40m/s with an aero... is that correct?.. anyone?
    Jeepsandbass's Avatar
    Jeepsandbass is offline Member
    Apr 2017
    Clinton NC
    93
    53 Post(s)
    So I should be fine with my design?
    Apr 2017
    Clinton NC
    93
    53 Post(s)
    I don't exactly understand the graphs
    Apr 2017
    Clinton NC
    93
    53 Post(s)
    And your saying I should go with a square port instead of aero port?
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    it's a little more port area and if you round over the ends I think you'll be fine with the power you got... the modeling looks like you need more area to avoid compression... that 6" aero is just a little bit high velocity wise with your power... if you want to power it with all your available power and avoid compression... yeah... I think a 6" or even a 6 1/2" square is best... maybe someone else will weigh in... I'm still learning after +25 years and consider myself an enthusiast only... just trying to help
  9. #9
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    5,914
    18
    29 Post(s)
    2379 Post(s)
    Quote Originally Posted by Jeepsandbass View Post
    the 6" is fine. as long as air velocity is under 80 ft per sec., he's showing it under 50 fps., mine is 75fps on slot port
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  10. #10
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    Pa!... thats m/s...
  11. #11
    Jan 2017
    NC
    5,914
    18
    29 Post(s)
    2379 Post(s)
    meters why u do meters? yeah port should be bigger then..
    2 ohms rule
  12. #12
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Because it's my computer...and I use it... no special reason... lol!
  13. #13
    Apr 2017
    Clinton NC
    93
    53 Post(s)
    So a 6 inch aero port at 16 inches long is fine lol? I'm so confused.
    ---------- Post added at 02:26 PM ---------- Previous post was at 02:25 PM ----------
    What is that program called btw?
  14. #14
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    It's modeling software... Winisd... takes awhile to learn... it's the best free one out there everyone says.. I use it in conjunction with Torres... it took my dumb azz 2 months to learn how to just get it to work... I'm still learning to translate the results to the real car environment... Just trying to help out BTW
  15. #15
    Jan 2017
    NC
    5,914
    18
    29 Post(s)
    2379 Post(s)
    no thats a tad high i use fps he used meters u want air velocity under 100 fps.. his is showing u at like 120fps with 6" port., i thought 6"would be good but it's the power u are running thats puts it over the recommended air speed.. u would need 8" port maybe or slot port to keep u around 70 or so fps.. if u were only using 1/2 that power it'd be fine..
    2 ohms rule
+ Reply to Thread
  1. New Box for American Bass XFL 15s on SQ3500
    By Savackz in forum Enclosure Design & Construction Help
    Last Post: 04-01-2016, 08:33 PM
  2. Need help with box for 6 XFL 10's ASAP
    By The_Dealer in forum Enclosure Design & Construction Help
    Last Post: 02-11-2015, 03:28 PM
  3. need help with box for truck!
    By NegativeEffect1 in forum Enclosure Design & Construction Help
    Last Post: 04-28-2004, 12:03 AM
  4. need help with box for old subs
    By ckarls2000 in forum Enclosure Design & Construction Help
    Last Post: 03-15-2004, 09:52 PM
  5. Need help with box for 15" SX Series sub by RE.
    Last Post: 02-08-2004, 01:12 AM
