+ Reply to Thread
Results 1 to 10 of 10
Reload Thread: Port Area Trials...
    iLL Ridge's Avatar
    iLL Ridge is offline Senior VIP Member
    Sep 2010
    NC
    478
    34 Post(s)
    Port Area Trials...
    So I built a box for 2 xfl 10's.
    Subs and ports Up.
    Powered by maybe 600 watts per woofer.
    Box is double baffle. roughly 4 cubes gross ~ 3.4 net.
    Removable port baffle.
    Originally used 2 - 3" round ports x 12" long/ no flares.
    Tuning [email protected] 27hz.
    The 3" ports sounded great in my suv.
    It KILLED the lows....
    It is low on port area, I had severe port chuffing.
    Changed ports out to 4" round. 13" depth. Tuning calculated to [email protected] 34hz.
    No port noise..... but I lost the low, lows.
    Strangely, even so, it seems like the smaller ports were louder overall.
    That may be just subjective though, not sure.
    Attached Thumbnails Attached Thumbnails Port Area Trials...-img_20170811_125346-2.jpg   Port Area Trials...-img_20170811_111609-2.jpg
    VW Touareg Black
    Chinese Android HU
    Factory doors/ Factory amp
    Mb Quart da 2400.1
    Single XFL 10 dual 2
    iLL Ridge's Avatar
    Sep 2010
    NC
    478
    34 Post(s)
    Re: Port Area Trials...
    I'm going to try and lengthen the 4" ports to 18" .
    That should bring the tuning back down to 30hz.
    Hopefully that will do it.
    My question is, I had a another box for a single 10.
    2 -2 x 12 inch aeros in 1.2 cubes. That's still very low on port area, especially with 1k watts+.
    .....But It slammed!, Could not detect any port noise, and the lows were Heeeaavy!
    In the small box, did the aeros make that much of a difference in port noise/velocity/turbulence???
    Also with that little amount of port area, was I having port compression?
    Will I have port compression with non-flared 4 inch ports?
    VW Touareg Black
    Chinese Android HU
    Mb Quart da 2400.1
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline NOT TO OLD TO BASS
    Jan 2017
    NC
    4,786
    17
    23 Post(s)
    1937 Post(s)
    good looking box.. flared port certainly has less noise idk that they can change the compression. 2-2" not as good at 1 4" yeah but for 1.2cf it's a tad less port than u want but flared i think they say 8-14 sq per cf., so should be good on that 1
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
    Jan 2017
    NC
    4,786
    17
    23 Post(s)
    1937 Post(s)
    i meant to say the single 10 box was good the dual 10 3.4cf u have only 6sq in port per cf thats not enough,, i'm gonna try old 10 on wins list see what it looks like........... oh man i just modeled some old rf subs and at 3.4ad with 700watts listed (after rise) port air velocity showing 145 fps u want about 1/2 that., it's not good man sorry..
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,117
    217 Post(s)
    7268 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    gramps just NO... just no... lmao... You dont model rockford subs and tell him his sh*t doesnt work when his results say differently. You arent helping anything here. Leave the getting loud advice to people who know what they are doing please.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Jeffdachef's Avatar
    Feb 2013
    15,117
    217 Post(s)
    7268 Post(s)
    Quote Originally Posted by iLL Ridge View Post
    Can you do an octoport? a single 5.5 diameter port would be under the threshold of port noise. If possible have the port fire to the rear or side... If you are firing up, make sure its long enough so the port is very close to the roof if you want lows and proper loading.
    To explain your results, this is why we design boxes around the power you will use. Those XFLs with low power will require much less port area to get loud because they arent building enough pressure. However when you put more power onto them, the port you need to use will need to be much bigger to accomadate or else you run into both noise AND compression AKA you wont get any louder when you throw more power onto them.
    With it stands now, if you want to get loud with those 4 inch ports, you'll need to throw 1500 rated watts per woofer or about 800 clamped in order to get louder output. OR you make the box bigger if you want lows. More power you have, the more air will be displaced which means you need a bigger hole to breath. However if you dont have much power and too big of a hole, you arent building up any pressure.
    This is why you usually dont follow the port per cube rule to the teeth, thats just a general guideline for noobs. The actual numbers can vary greatly depending on driver parameters, power and other factors.
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,600
    15
    35 Post(s)
    3805 Post(s)
    This discussion is absolutely worthless if you don't own an SPL meter or RTA and graph your output/frequency response.
    Or simply state "lower tuning sounds better to me".
    iLL Ridge's Avatar
    Sep 2010
    NC
    478
    34 Post(s)
    Lower tuning DOES always sound better to me.
    I seem to like lower than recommended port area in ALL of my boxes.
    What am I sacrificing by using small port area?
    Also remember.... The 4 inch ports are for the 3.5cu ft net box.
    That's still only 7.2 sq in/cube
    VW Touareg Black
    Chinese Android HU
    Mb Quart da 2400.1
  9. #9
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    5,775
    18 Post(s)
    1228 Post(s)
    Aeros can do 7.2^2 ok on low power. Not ideal for very high xmax drivers like the new sundown platforms, but ok for most subs.
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
  10. #10
    iLL Ridge's Avatar
    Sep 2010
    NC
    478
    34 Post(s)
    ok, so I switched out the ports.
    Went with 2-4 inch x 19 inch no flares.
    Tuning calculated @ 29hz
    Had to flip box facing rear hatch to fit ports.
    Gets down pretty good.
    I still drop off at 23-22 hz though.
    I'd like to play flat from 19-40.
    Pretty loud and stout though, It's probably as good as it's going to get without getting too bottom heavy.
    Attached Thumbnails Attached Thumbnails Port Area Trials...-img_20170813_142813.jpg
    VW Touareg Black
    Chinese Android HU
    Mb Quart da 2400.1
+ Reply to Thread
  1. Port Area Question
    By Acidburn in forum Enclosure Design & Construction Help
    Last Post: 04-30-2004, 02:01 AM
  2. Port Area?
    By Bryan08 in forum General Discussion
    Last Post: 04-26-2004, 01:24 AM
  3. Port Area for 2 15HC's
    By TheVanMan in forum Enclosure Design & Construction Help
    Last Post: 01-27-2004, 11:05 PM
  4. minimium port area
    By AMD in forum Enclosure Design & Construction Help
    Last Post: 08-21-2003, 11:56 PM
  5. port area
    By actlsub in forum Enclosure Design & Construction Help
    Last Post: 05-28-2003, 09:28 AM
