+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Reload Thread: box frequency check .
    riddla's Avatar
    riddla is offline CarAudio.com Elite
    Dec 2003
    nf
    675
    25 Post(s)
    According to re audio box calculator. I've put in the following for a 15in subwoofer.
    36 wide x 18.5 high x 15.5 deep.
    A square port width of 3.5in and a square port length of 16
    It's giving me a box volume of 3.7cubes and a frequency of 30hz.
    Can you double check if this is correct please in comparison to other programs you may be using. Thank you.
    shredder1's Avatar
    shredder1 is offline CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Re: box frequency check .
    Quote Originally Posted by riddla View Post
    Why don't you tell us what sub it is... someone might model it in Winisd for ya' and if you give vehicle dimensions maybe help with a box... RE Box calc is a joke BTW
    The Budget Beater Blazer Build... Lookin' for those Basshead Problems!
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    I used Torres and entered .2 as the driver displacement, double baffled and slot ported on one end of the enclosure (see pic below) for a single 15" sub... This IS one of the most accurate calculators but your sub/power and box should be modeled together in Winisd first... then a calculator used to do it right...
    If you list your sub, amp, what load the amp is at and max available space (be sure it can be installed)... the sub/box combo can be optimized for your ACTUAL power and vehicle...
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,265
    15
    39 Post(s)
    4238 Post(s)
    Quote Originally Posted by shredder1 View Post
    Why would you build a port that big just to stuff it with only 2" of clearance to the rear hatch?
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Quote Originally Posted by hispls View Post
    Good question... IDK... this is a pic I pulled of the internet to illustrate the port configuration I used in Torres... why they did that?... IDK
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    Here is the subwoofer specs
    Attached Thumbnails Attached Thumbnails box frequency check .-screenshot_2017-08-12-12-40-34.jpg
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    here is the link if the above isn't clear.
    http://www.google.co.uk/url?sa=t&rct...ioYc6KWpWxPpdg
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    OP... can't read that... is it a Fusion?.. wattage rating (RMS)... what amp, car and dimensions... I'm not even sure that sub is worth modeling...
  9. #9
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    I was hoping for a frequency in the 28hz to 333hz range.
  10. #10
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    Try the link. it works . no car specific as yet. just trying to get a box done. I have a incriminator IA20.1 AMP.
  11. #11
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    OK... I'll give it a try but you need to list your amp and is it a dual 4?.. I'm just trying to find the correct vent size...
  12. #12
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    OK. Yes.Its the IA20.1 amplifier. the subs are dual 4.
  13. #13
    riddla's Avatar
    Dec 2003
    nf
    675
    25 Post(s)
    Yes its a fusion. the good old ones.
  14. #14
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    Subs?... as in plural?.. be very specific please... if you're putting them on a IA 20.1 at 1 ohm, I'll have to account for the power for sure... I don't think those subs will hang BTW...
    I already modeled ONE... LOL!.. now you say two?.. I'll look but I thought you said a 15 in the first post...
  15. #15
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,560
    20 Post(s)
    719 Post(s)
    28 to 333 hz?.. LOL!... that's setting the bar pretty low... you must mean 28-33 hz... correct?.. that's not a great sub... are you in a location that does not have better options?
+ Reply to Thread
  1. Box Design Check
    By 00StealthSE in forum Enclosure Design & Construction Help
    Last Post: 05-13-2005, 11:17 PM
  2. Kicker Solo X Box-Please check my #'s
    By JCivicHb in forum Enclosure Design & Construction Help
    Last Post: 05-03-2005, 04:33 PM
  3. ported box help...check my calculations..
    By Devin_9_2004 in forum Subwoofers
    Last Post: 11-05-2004, 04:18 PM
  4. box frequency xxx?
    By misterio in forum Enclosure Design & Construction Help
    Last Post: 10-12-2004, 10:49 PM
  5. box frequencies
    By Kdubs20 in forum Enclosure Design & Construction Help
    Last Post: 05-18-2003, 10:20 PM
