+ Reply to Thread
Page 1 of 68 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 51 ... LastLast
Results 1 to 15 of 1013
Reload Thread: The do's and dont''s of my first wall....it seems like something isn't right....
    ferguson621's Avatar
    ferguson621 is offline Senior VIP Member
    Feb 2015
    Olathe, ks
    406
    4 Post(s)
    232 Post(s)
    Ok so i finally found an engine for my car and just finished doing my motor swap because i blew a hole in one of the pistons so i wasnt able to test anything till now because i dont like to run my amp on 12v.....so anyways csc_stang hooked me up with a design! And i most definitely appreciate your kindness in helping me! Thank you again....I'll include pictures also for a visual....but the subs seem like they either dont like being tuned to 30hz....it could just be me because ive never tuned below 35hz....but they don't really hit the lows that good, ive tried playing a few songs that were like 26-32hz and they didn't sound good at all, and when they hit from 40hz on up you can really feel it, but it also sounds like the wood is slapping together really hard or it could be my sunroof or back glass....i havent been able to get out and look because i live in a small town and the cops love to mess with me because they have nothing else better to do. So i need some pointers on what i should do for better bracing and what i should do about the tuning.....because they're recommended tuning is 32hz
    Alternator: Mechman 240 amp
    Head unit: Pioneer X7500BT
    Subs: Two DD 9515I's
    Sub Amp: Taramps 8k
    Door speakers: Two soundqubed 6.5" coaxials temporarily
    Tweeters: Need new one's
    5 ch amp: Memphis PRX 5.550
    Chris McNeeley's Avatar
    Chris McNeeley is offline Red Light Ear Rapist
    Jul 2016
    Toledo, ohio
    30
    311
    204 Post(s)
    Re: The do's and dont''s of my first wall....it seems like something isn't right....
    I would throw away those subs before i wasted the time and money on a wall for them.
    Team Bang Hard Ohio Chapter
    2013 Subaru Legacy B-Pillar
    4 Crossfire v4 18s
    4 Crossfire 4k's
    2 Crossfire 2000.4s with Ampere JM1 Dsp
    3 SINGER 270's + MI Solar 115ah 18v + 16.5ah 12v x2
    Feb 2015
    Olathe, ks
    406
    4 Post(s)
    232 Post(s)
    Why do you say that?....just curious......judging by your setup i know your input is worth listening to lol..i have upgraded recones for them....xl aluminum coils, 8 layer spiders with extra spiders for added stiffness and wide roll surrounds, they're ct sounds meso 18's with psi recones
    Sub Amp: Taramps 8k
    Jul 2016
    Toledo, ohio
    30
    311
    204 Post(s)
    Quote Originally Posted by ferguson621 View Post
    Ohh, well pics werent up when i posted, and your sig said stock hds3's, which everyone hates. Seal the wall off from the trunk is my advice to you.
    4 Crossfire v4 18s
    4 Crossfire 4k's
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    2,175
    44 Post(s)
    1397 Post(s)
    Yep u need to seal it off... and for wood slapping sound. It very well could be. That's a crazy looking box with wood all over the sides and back
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,722
    17
    30 Post(s)
    2677 Post(s)
    does the front wall move? u have bracing holding front of box to back?
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    Feb 2015
    Olathe, ks
    406
    4 Post(s)
    232 Post(s)
    Lol sorry about that. I keep forgetting to update my sig info.....and hertz mafia I was trying to stack the 2x4's so they would brace the outside of the box so it won't flex because I only have one layer all the way around and double baffled on the front....How many layers do you and chris recommend? Like I said this is my first wall lol. I jumped in not knowing anything about building a wall.....but I love to learn new things and I'm a quick learner. That's also why I was asking for help from people who have a wall and are doing 150+ like you and chris. Cause I knew you would definitely chime in on my thread which I do appreciate by the way. Oh and for internal bracing I have 45's in the corners and two 2x2's going front to back and two 2x2's going vertically. And the 2x12's on the back are for added external bracing so it won't flex as much. Oh and what would be the best/easiest way to seal it off completely?
    Sub Amp: Taramps 8k
    Jul 2016
    Michigan
    2,175
    44 Post(s)
    1397 Post(s)
    If I were you I would scrap that enclosure and start over... the enclosure Should be at LEAST doubled walled all the way around and a triple+ baffle, along with bracing... I'm not hating but instead of trying to add random pieces of wood just build it right from the beginning.
  9. #9
    BMayes36's Avatar
    BMayes36 is offline Senior VIP Member
    Jul 2016
    NYC
    229
    106 Post(s)
    Technically that's not a wall, just a big ass box. I agree that you should start over. Seal off the wall, at least double layers all around and plenty of internal bracing (I like using threaded rod). Flexing could be the cause of all you problems.
    *awaits boomin tahoe to dislike my post and add his negative comments
  10. #10
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,526
    29 Post(s)
    2251 Post(s)
    Quote Originally Posted by BMayes36 View Post
    Same was said about my wall lol.
    Anyway op, what type of wood did you use as that seems like normal cheap wood?
    The wood type can make a difference and how it is sealed within the actual box.
    My issue was i didnt apply enough force on the wood on the roof part that it caused wood slap in between the layers.
    Next wall if i make one will be difference 🤣🤣
    Sent from my Z970 using Tapatalk
  11. #11
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    if you need some help with how to brace i can give you a few pointers that would drastically help.
    you need help making a seal and panels around the box?
    the external braces aren't doing much except making it look back.
  12. #12
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,378
    110 Post(s)
    7897 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    Remember when you had a big box instead of a wall? Man I gave you a lot of **** over that. Those where the days.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  13. #13
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    also glass the inside and outside of the ports
  14. #14
    Jul 2016
    Michigan
    2,175
    44 Post(s)
    1397 Post(s)
    Quote Originally Posted by LosIsATool View Post
    And I was still louder then you, ...
    I just seen paper maker say in another thread a dude with 2 18s and taramps 15k should be doing 162db... lmao... papermaker has NOoooo idea what it takes to do a 162db... my fvcking head almost exploded when he said that.
  15. #15
    cfox10's Avatar
    cfox10 is offline Rock the house.
    Mar 2011
    Tillamook, Oregon
    1,956
    3 Post(s)
    811 Post(s)
    That was aimed at me and I didn't bother responding for the same reason. It will be 30k though fwiw
+ Reply to Thread
