Results 1 to 2 of 2
Reload Thread: Fi Q 15" 6" aero port build questions
    Ace87's Avatar
    Ace87 is offline Member
    Jan 2015
    NE Pennsylvania
    1 Post(s)
    39 Post(s)
    Icon14 Fi Q 15" 6" aero port build questions
    I'm about to start building an enclosure for a 15" Fi Q d2 and I'm using a full length 6" (17-18" long) Aero port kit from parts express. Which would work better? 3.0 [email protected] or 4.0 net @29hz, or somewhere in between? It will be run off a Sundown saz-1500v2 @ 1ohm. Half of the music I listen to is rebassed-slowed, and this is a daily driver. I'm also wondering, has anyone ever done any testing on which works better in a trunk, a driver side firing aero port, or middle of the trunk firing aero port towards trunk lid/license plate? Port will be run all external. This will be in the trunk of a Buick. Any input is appreciated guys, thanks.
    '03 Buick -
    Alpine CDE-164BT
    (4)Mclaren MLT-60 +(4) Crescendo PWXs - Sundown SAX-125.2
    Sundown SAZ-1500 - Fi Q 15" 3.99net @29hz- 6" Aero Kit
    2/0 welding cable w/ copper SHCA 1/0 amp inputs, lugs, & fusing, Stinger 4awg, Stinger 6000 rcas
    Singer 320 6 phase hairpin alt
    XS Power A-3400 upfront- XS Power D975 trunk
    SHCA 38.5sqft 120 mil deadener - SMD VM1
    jRi0T68's Avatar
    jRi0T68 is offline Senior VIP Member
    Jan 2016
    Olympia, WA
    132 Post(s)
    Re: Fi Q 15" 6" aero port build questions
    My previous box for my Q15 D2 was 3.9 ft³ tuned to 32, but with two 6" aero ports. Originally had it on two 4" aeros, and definitely got louder going up to 6s. Honestly, I'd give it 4 ft³, and see if you can go up to a single 8 or two 6" ports.
    Mine is in a 6th now and is just all around better for it.
Tags for this Thread
