Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Building in trunk?
  1. #16
    HI-C's Avatar
    HI-C is offline Senior VIP Member
    Jul 2012
    Las Vegas
    256
    17
    4 Post(s)
    41 Post(s)
    Re: Building in trunk?
    Quote Originally Posted by mlstrass View Post
    last one I did was 2 15's in a G6....prebuilt it outside the vehicle with no glue, then reassembled in the trunk. Was a PITA but most in trunk builds are....
    ^^^^ what he said ^^^ what's up bro?
  2. #17
    loudenuff's Avatar
    loudenuff is offline CarAudio.com Elite
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Quote Originally Posted by The Camry View Post
    If i ever did a full spl trunk build. Id probably go talk to a boat building/repair shop and ask them how much they'd charge me to spray fiberglass on the trunk walls after taking out all the panels. Ive always seen boxes built in trunks but for weight and uniqueness factors, a front baffle into the cabin made of 1'' mdf and the rest of the trunk made into a perfectly formed box. That'd be pretty cool.
    https://www.youtube.com/watch?v=A8j5Kmuo0_U
    I like the thought of this but I wouldn't want to just for the reason being I want to be able to trade this car in in a few years. Lol and I also would like to retain my rear seats which do not fold down.
    I wanted to port through the arm rest because I feel like that'd be the most convienent way of porting into the Cabin without cutting metal.
    How would this work with the trunk latch though? That's my only other concern because I have no way of opening the trunk without the electrical button for my trunk to open and this gives me the feeling that I'll be putting a hell of a lot of pressure on it. It's a nice idea though..... maybe if I can find a cheap honda on Craigslist to give it a shot with 😂
  3. #18
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Quote Originally Posted by jRi0T68 View Post
    I'd say it came out pretty well. Need my new alt and a bigger amp to see what she's really got in her, and a lot of testing different ports.
    Now that does look pretty wicked. How does it sound? I feel like sealing off both back and front waves would cause cancellation no?
  4. #19
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    I'm just un decided on how to do my baffle and port. I bet that pounded tooshy tho
    ---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
    If you're firing through the equivalent of an armrest, you're better off doing a 4th or 6th if you can.
    How would I know if my speaker would perform well in a band pass? I like the thought of that
  5. #20
    jRi0T68's Avatar
    jRi0T68 is offline Senior VIP Member
    Jan 2016
    Olympia, WA
    216
    132 Post(s)
    Which sub? I'm sure we can help you figure out if a 4th or 6th is a good option.
  6. #21
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Sundown x 18 v1 d2. Sundown doesn't have specs up for v1 but Amazon does surprisingly
    John Kuthe...
  7. #22
    The Camry's Avatar
    The Camry is online now Hey, I Try.
    Sep 2013
    Western Oregon
    2,799
    13 Post(s)
    1259 Post(s)
    Quote Originally Posted by loudenuff View Post
    You'd more than likely have to take out the torsion bars and build a small box(like with cardboard) around the actual latch as well as the bars that move when you open the trunk. The vertical movement ones. Its just more of a neat idea than anything.
    Trunk cars are already a Pos to deal with bass wise. Without seats folding down. Your basically left with a strongly deadened and reinforced IB install using the back deck.
    4th/6th is cool and all but **** difficult to get right and I doubt you (or I) have the knowledge to make one right.
    Sent from my SGH-T999 using Tapatalk
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
  8. #23
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    879
    1 Post(s)
    227 Post(s)
    Sub up port back/ side will be your only option I think
  9. #24
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    okay so I worked out what kinda space I have and I need opinions. I can do 35w 15h 32d. I obviously don't have enough space for the sub to fire horizontally so what should I do? this would be a hell of a lot easier if I had some 12s lol
    John Kuthe...
  10. #25
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    13,546
    39 Post(s)
    5715 Post(s)
    You didn't look very hard...
    X REV1 SERIES
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  11. #26
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    X REV1 SERIES
    didn't think to hit discontinued. how would building an enclosure in trunk go, while firing up?
    Might have someone interested in buying locally so ill probably just end up with a Q Neo 15. But I'm curious if anyones ever done a trunk wall, firing up, and sealing off behind the woofer in that way?
    John Kuthe...
  12. #27
    The Camry's Avatar
    Sep 2013
    Western Oregon
    2,799
    13 Post(s)
    1259 Post(s)
    Sure why not. Just remember. You're limited in bass by how much air you are letting get to the cabin, sure you can fire it up and seal off the rest but you're limited by the little air that is getting through the back deck. basically you are trying to do an spl build in a trunk which is **** difficult, with seats that down fold down and its all pushing a boulder uphill. Start cutting metal or figure out how to fold your seats down. Hell, you could even rig up something to make them fold down.
    If you just want bass for your system, get subs that fit in the back deck already and be done with it.
  13. #28
    Jul 2005
    WA
    13,546
    39 Post(s)
    5715 Post(s)
    You keep questioning the same thing over and over again. Why not sell the sub and go with a few smaller ones, keep it simple...and build a ported box, fire thru rear deck. Unless you want the frustrated headache and wasted time on trying to accomplish something that sounds like you've never done before.
    These guys here have done trunks builds....if they say it can be done but is abitch, then I'd trust them. if John Kuthe mentions anything about it, ignore him.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
