Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Sundown Audio SA vs Ultra enclosure
  1. #16
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,634
    28 Post(s)
    1467 Post(s)
    Re: Sundown Audio SA vs Ultra enclosure
    Port area. 15 sq inches per cube
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
  2. Likes Troponin liked this post
  3. #17
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,457
    42 Post(s)
    6144 Post(s)
    Quote Originally Posted by LosIsATool View Post
    It's reliable. They get a good cut if they sell at retail. It's easy to work with for a shop
    Nobody buys retail tho...if it/they can be had cheaper elsewear.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
  4. #18
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,188
    110 Post(s)
    7813 Post(s)
    Oh yes they do. If people didn't then every shop would be closed down.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  5. #19
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,100
    243 Post(s)
    7863 Post(s)
    Quote Originally Posted by Troponin View Post
    SAE1000D Amp.
    Looking for it to hit pretty hard. Want good SPL without completely sacrificing sq. It's going in to a Dodge Charger, so it will be in the trunk and need it to be loud and hit hard to get through the seats etc.
    Get the cab 1600.1 instead and do 2 cubes tuned to 35 to 37 for your musical preference.
    Why 1600? Because box rise. Plain and simple. Youll see closer to 500 to 800 actual watts after rise.
    With the sae 1000.1, more like 300 to 400
    Its not that they are bad amps, its how physics works. Wired to 1 ohm, you will end up around 2 to 3 ohms with box rise.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
