Results 1 to 6 of 6
Reload Thread: Trouble in the trunk
    SgtHawk's Avatar
    SgtHawk is offline Member
    Aug 2014
    United States
    67
    41 Post(s)
    Alright so heres the deal, I have a sundown X15 v2 on a DC2k at 1 ohm. Box specs out to just under 4.25cuft at 29hz with 60sqin of port area.
    Problem im having is that there's very little actual bass whether it be felt or heard, so much so that my old JL13w3v3 on a garbage hifonics amp in a ****** prefab in my old hatchback was significantly louder to the ear but yet i can see the dash and steering wheel flexing the slightest bit, all my gauges start jumping around and i even get noticeable windshield flex on certain notes from certain songs but in the car the actual output is just disappointing if that makes any sense. Theres basically alot happening with very little audible output even up into the 30s and 40s and higher not just the lower end stuff.
    So my question is, is my box garbage, am i lacking that much port area, should i try sealing it off or rebuild it or are front firing trunk builds really this much of a pain to work with or maybe all 4?
    cheers and thanks in advance.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Re: Trouble in the trunk
    Hmm that is interesting. Box sounds about right. I'm wondering what you did diff to the previous system vs what you have now.
    I would try sub positions in your trunk. Turn it around, face cone up, etc. Something's gotta give.
    You sure the sub is wired correctly?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    13,414
    69 Post(s)
    2 Thread(s)
    5552 Post(s)
    Sounds like the pressure isnt getting into the cabin. Something is restricting it..
    i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,804
    233 Post(s)
    7687 Post(s)
    Quote Originally Posted by SgtHawk View Post
    if you are facing the sub and port inside the cabin without sealing EVERYTHING off from the trunk aka the rear seat opening, rear deck and wherever any holes might lead to the trunk, then you will get Sh*t for output.
    If you dont plan on sealing, fire it to the trunk.
    If you want to do it right, make a proper trunk wall and make sure not even a peep of air gets through to the trunk.
    What you are doing is cancellation hell = zero bass.
    Also a hatchback can get WAY louder than a trunk no matter how you look at it. a 12 in a trunk will equal to an 8" in a hatchback. Quality of gear can be easily outdone by vehicle acoustics and proper enclosure loading and orientation which are the basics of how to get loud.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,950
    15
    36 Post(s)
    4040 Post(s)
    If you planned on playing actual music 29hz tuning was probably not a great move.
    SgtHawk's Avatar
    Aug 2014
    United States
    67
    41 Post(s)
    Thanks for the input y'all. I went back through and everything is wired up proper and all seems to be in order everywhere else.
    my next plan was to pull the box out and properly seal it all off and deaden the rest of the car I just figured I'd get some input from you guys beforehand in case there was some other outstanding flaw with the setup that could be fixed before sealing off. Ill probably jump on getting it sealed when it gets a bit warmer and drier out. Cheers.
