Results 1 to 10 of 10
Reload Thread: How much fiberglass and resin
    ashren315's Avatar
    ashren315 is offline Senior VIP Member
    Aug 2016
    Canton, MS
    174
    2 Post(s)
    83 Post(s)
    I'm about to order my fiberglass and resin from UScomposites and I was thinking that 2 gallons resin and 10 yards by 38" 1.5oz fiberglass matt should be enough to do my two kickpanel enclosures and a 1.4 ft^3 spare tire well enclosure. The top of the enclosure will be MDF so only the shell inside the spare tire well will be fiberglass and will house one 12" sub with about 300 watts going to it. Was going to do 5 or 6 layers.
    Does this sound like enough fiberglass and resin for this project?
    ashren315's Avatar
    Aug 2016
    Canton, MS
    174
    2 Post(s)
    83 Post(s)
    Re: How much fiberglass and resin
    Anyone?
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,102
    15
    38 Post(s)
    4138 Post(s)
    Sounds as good a guess as any. You really won't know until you start laying it up how many layers it'll take to make your spare tire well feel solid. I did that ages ago and I do recall it took a bit more than I planned, but then again it was the spare tire well in a 1980 Lincoln Town Car which is pretty big.
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Get more than you think you'll need then you will have plenty to play with AND save for later for possible fracture repair, heaven forbid! ;-)
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,257
    41 Post(s)
    6035 Post(s)
    Yes, listen to John. He's the car audio guru around here.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  6. Likes JohnKuthe liked this post
  7. #6
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Judge my suggestion! I should have gotten more Damplifier Pro! Like fiberglass mat you use up a ton of that stuff!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  8. #7
    staan's Avatar
    staan is offline CarAudio.com Elite
    May 2016
    new orleans, la
    514
    336 Post(s)
    common sense stuff get more than you need, suggestion rating 0.0
  9. #8
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    Quote Originally Posted by staan View Post
    I've found IN MY EXPERIENCE that common sense is not nearly as common as it's purported to be, often! I said I wished I'd gotten more Damplifier Pro. Luckily I'd bought some BQuiet. Not nearly as good as Damplifier Pro but certainly better than nothing.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  10. #9
    staan's Avatar
    May 2016
    new orleans, la
    514
    336 Post(s)
    Quote Originally Posted by JohnKuthe View Post
    John Kuthe...
    I can completely understand that common sense is not common in your experience.
  11. Likes JohnKuthe liked this post
  12. #10
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,057
    13 Post(s)
    1194 Post(s)
    I live with college aged kids, it's rampant! Not all but some more than others.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
