The sealed ML2500 way back in an FG box in my A4 Avant
JL 6.5's in the front doors
AP1040 bridged driving them.
2 Sundown E8's in 1.1cu ft tuned to 30Hz.
700rms @ 2Ohm Cadence... let's see what the the E8's can take
Keep in mind the $900 ML is being replaced with. $250 SXX. Output capability and overall performance suffer.
Rich V.
got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
My 1966 MGB: http://www.mgexp.com/journal/keephopealive
Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
True, the Hertz is a truly quality bit of kit. In the 0.5cu ft sealed box it really shone and kept my trunk space open for my bike and kids stuff.
However, being SVC 4ohm it was at its limit and my amps limit in the new car I have more space and I wanted to be able to get down to <2ohm to get the most out of the KAC9104D
It is for sale locally and at only £90 I have local Chavs wanting to give me £50 for it like the rest of the cheap crap on Craigslist
Box is out and under re-construction.
With the internal port out the volume is back up to about 34 L (1.2 cuft)
Got a new 4 post terminal plate, flushed it into the side
Soldered on the '8ga' power wire on, it's the same thickness as the new 12ga speaker wire
Made the new external port, tune is about 35Hz
Port on, put it in the car and made a cardboard template of the baffle.
Neat!
Sent from my SGH-T999 using Tapatalk
Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
80% of your total volume is (max volume) X 0.8.
Example is 40(is your max volume so, 40 X .8=32
Some paint and sub back in, merry Christmas to me!
Some of the weirdest enclosures I've ever seen. Looks kinda small for that 12.
97 4 dr. Tahoe
Interstate battery
Alpine 9835
Polk Audio MM6501 comps
It is a little, Re spec is 1.5cuft net for the 'compact' design and I'm more like 1.2
I will run it for a while like this, will be wired to 1ohm so amp spec is 900rms, no idea if it will actually do close to that.
Will see how the SXX and the amp (KAC9104D) play together.
I may have access to a Massive Audio P1500.1D if I do get hold of it I will see how that sounds, if it seems worth it I may then build another box with Re's other recommend size 1.9cuft net
Box is in and the 12ga speaker wire is crimped up and in too.
First 1/2 hour out in the car with no kids...
The box is much flatter through the lows now, it feels louder and the (admittedly poor) IPhone dB meter has it up from 122 to 124.3 on the same extended note in the same track as before.
The plot from the box calculator app is in agreement, getting the 3L back and tuning a bit lower flattens it out.
I have also wired each VC to the speaker outs on the amp as the diagram below, I'm not sure if it's now loading the amp to 2ohm or 1ohm?
Should I bridge +ve to +ve and -ve to -ve to make sure it's parallel and presenting a 1ohm load?
Is sub d2?
Team Flex Issues
JVF Customz
REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
Yes Re SXX 12" D2
Bookmarks
