Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 61
Reload Thread: Anyone fancy helping me - Hertz ML2500 10"
  1. #16
    jRi0T68's Avatar
    jRi0T68 is offline Senior VIP Member
    Jan 2016
    Olympia, WA
    216
    132 Post(s)
    Re: Anyone fancy helping me - Hertz ML2500 10"
    You're incorrect in your understanding of ported vs. sealed.
    You'll also likely ignore this advice, as you have when it was given to you before, but if you're not pleased with the bass response, you're better off finding a way to put a ported 8" near the hatch than any 12" in that cubby hole.
  2. #17
    JohnKuthe's Avatar
    JohnKuthe is online now CarAudio.com Veteran
    Sep 2016
    Missouri
    2,034
    12 Post(s)
    1177 Post(s)
    Quote Originally Posted by jRi0T68 View Post
    You're indirect in your understanding of ported vs. sealed.
    Again, you are suggesting changes to my system design I have repeatedly said I am NOT gonna do! Despite the fact that yes they may result in better sound for me. Mine is one of the most restrictive autos you will ever install a sound system in, largely due to Chrysler's auto designs and my desire to remain within those restrictions too!
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
  3. #18
    jRi0T68's Avatar
    Jan 2016
    Olympia, WA
    216
    132 Post(s)
    Your build is only restricted by your own arrogance, ignorance and stubbornness.
  4. #19
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,034
    12 Post(s)
    1177 Post(s)
    And the physical restrictions of the building environment!
    I am NOT getting a new car or any or much new equipment! I have stated that repeatedly, and yet Caraudio.com keyboard jockeys seem to always want to get on here and tell me THEIR fantasy builds! Ignoring the restrictions of design I am both physically restricted to and have already decided upon and am comfortable with.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  5. #20
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    13,439
    39 Post(s)
    5668 Post(s)
    Not like we have been thru challenges ourselves.....when dealing with builds weather big or small.
    What does it take to get rid of this mutherfucker?!
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  6. #21
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,678
    15
    35 Post(s)
    3855 Post(s)
    Quote Originally Posted by JohnKuthe View Post
    Could yes, but a sealed enclosure normally just needs more power to achieve basically the same performance as a properly designed ported subwoofer enclosure, I think.
    John Kuthe...
    NO. A woofer designed to perform best sealed will have higher FS and low Qts. Low end will fall flat in sealed but open up with lots of "free" extension when you port it.
    That said, the Alpine looks like it should perform quite well in sealed box as well, having very similar specs as the Hertz OP is using. In retrospect I can't tell you really how "good" any of the ported type R's I've heard did, but I know they were impressively loud for what they are.
  7. #22
    Alex JB's Avatar
    Alex JB is offline Senior VIP Member
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    So looking at the recommended ported box size of 280x280x290 = 22.7 litres, it doesn't say but seems to be gross volume.
    Going to build a slot port across the bottom with the same area as the 77.5 dia port it suggests, prob 36x130 x250 long. Should take the net volume down to about 25litres.
    Aesthetically I'd like to put the port on the front face with the sub, but the HERTZ suggested box shows it on he side perpendicular to the sub, do you think this is critical for the tune/design?
    JL 6.5's in the front doors
    AP1040 bridged driving them.
    2 Sundown E8's in 1.1cu ft tuned to 30Hz.
    700rms @ 2Ohm Cadence... let's see what the the E8's can take
  8. #23
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    411 Post(s)
    2 Thread(s)
    973 Post(s)
    Quote Originally Posted by Alex JB View Post
    Port and sub on the same plane will yield best results. No, it won't hurt to run the port rear as well. The key is to have the driver as far away from the port mouth as possible.
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
  9. #24
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    Port made
    Got the sub out of the old box
    2 recessed and the mount
  10. #25
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    The backing plates are glued to the front.
    They take about 1.5 L each out so down to 25 L.
  11. #26
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    Slot port looks ok on front face
  12. #27
    hispls's Avatar
    Sep 2009
    9,678
    15
    35 Post(s)
    3855 Post(s)
    Looks pretty nice. I hope you're not using too much power. The other main issue about trying to tune low in a tiny box is that port volume starts to become really huge so you either shoot yourself in the foot by having to make the box really big just to fit the port, or you skimp on port area which can lead to troubles. On the bright side, you can easily get some weather stripping and a small scrap of wood to seal off that port for testing.
    It's a little late now, but port placement on the box (or more specifically where it fires in the vehicle) can make a dramatic difference, though this is exceedingly hard to predict and the ONLY way to optimize is either testing or talking to someone who has actually tested in the same vehicle.
  13. #28
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    Thanks,
    The box recommendation was 77.5 dia x 250lg so my 36x130 slot is the same area and 250lg as suggested.
    There is 80-100mm space behind the port so shouldn't effect it.
    The box is wedged against the back seats with the sub /port face facing the back of the trunk. Time will tell if this is a good layout.
    The sub is rated at 500rms 4ohm and my Kenwood 9106D amp is the same for 4ohm.
    I'm only using 4ga power/earth but the battery is in the spare wheel right next to the amp so runs are real short
  14. #29
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    Went with some rustoleum stone flec to cover the front
  15. #30
    Alex JB's Avatar
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    Some fluorescent paint on the inside back just for fun
    Wired to the terminal plate, used the wiring from the old box so it has to go in with the terminals on the plate side so the 'hertz' logo is upside down
    It looks lost in the A6 trunk.
