Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 56
Reload Thread: Sundown Audio SA12 bottoming out
    BRZ's Avatar
    BRZ
    BRZ is offline Fart Knocker
    May 2014
    NJ
    91
    31 Post(s)
    I have the sub in a sealed box, sized according to specs for a sealed enclosure (1 cu foot?). I am running it at 1000 x 1 @ 1 ohm. I recently switched head units and was adjusting the gain and noticed I was bottoming out at low freqs. I had my subsonic set to 0/off since setting this system up but decided to set it to 30/40hz to help prevent the bottoming out. Now the system sounds overall weaker. Is there anything else I can do to prevent bottoming out? Is it too much power? Any advice is appreciated.
    BSchrowang's Avatar
    BSchrowang is offline Budget Builder
    Apr 2016
    Peru Illinois
    491
    198 Post(s)
    Re: Sundown Audio SA12 bottoming out
    That sub would love a ported box but if you dont want to make a new one i would tbink your head unit has either a built in subsonic or the eq on the head unit is focused too high
    2010 Ford Crown Victoria Police Interceptor:
    2 American Bass XFL 15"s
    8 cubic foot box
    Taramps HD 3000 at 1 ohm
    Soundbox 1/0 CCA wire
    200 amp police alternator
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    I would love a ported box too, but I just do not have the space. I will take a look at the hu freqs.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,084
    40 Post(s)
    5958 Post(s)
    RMS(continuous power) for that sub is 650 watts. But could prob take a little more power. 1000 might be too much for it, turn the gain down, and check with settings on HU and amp.
    What's your max dimensions in your vehicle? And what vehicle is it?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    929
    1 Post(s)
    260 Post(s)
    Lower your ssf to roughly 25
    That should keep it from bottoming but not effect your output
    How big is the box?
    The sa's will take 600w free air before they get close to bottoming
    Also what songs are you playing that go that low?
  6. Likes Hertz Mafia liked this post
  7. #6
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Quote Originally Posted by tymoto21 View Post
    How big is the box?
    Set it to 25hz? Box is 1 cu ft IIRC. Its relatively small. The song I tuned with is DJ Khaled - Do you mind.
  8. #7
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Their site says 750. Its small, Subaru brz
  9. #8
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Does anyone have any thoughts on this? Is it possible that the sub is blown because it now taps when driven hard? It did not do this when I initially set up the system. I used to be able to drive it like crazy and it never tapped.
  10. #9
    Bomber Z's Avatar
    Bomber Z is offline Senior VIP Member
    Oct 2012
    Davie, Florida
    206
    22
    63 Post(s)
    Pull the sub and check the lead wires and around for rips or any damage.
  11. Likes shredder1 liked this post
  12. #10
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,836
    235 Post(s)
    7703 Post(s)
    Quote Originally Posted by BRZ View Post
    that song doesnt even play low....
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  13. Likes stromtrooperttr liked this post
  14. #11
    Jeffdachef's Avatar
    Feb 2013
    15,836
    235 Post(s)
    7703 Post(s)
    listing head unit models would help along with how you set your gains and ALL head unit settings as well. Yes list every single bit of your head unit setting even your max volume and your current settings.
  15. #12
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Which is even a bigger problem then
    Quote Originally Posted by Bomber Z View Post
    I did, everything looks fine. Could this maybe be the result of a sub not being tightly enough secured in the box (leakage)? Desperate for an answer to get this fixed.
    HU is one of them double din Android units from China. Gain set by playing a 50hz tone and increasing until distortion and then backing off a bit. Max volume is 30? EQ in android itself is flat, using viper4android with a u-ish shaped curve. Bass boost on amp is off. Loud is off.
    Could this be a problem at the source? I would think the issue is at the sub. The amps low pass and subsonic filters do not allow shrug that I do not want to reach it, right?
  16. #13
    Jeffdachef's Avatar
    Feb 2013
    15,836
    235 Post(s)
    7703 Post(s)
    Sounds like a dirty signal from a china head unit. How in the hell would it be the subs fault if the only thing you swapped is the head unit.
  17. #14
    Jul 2005
    WA
    14,084
    40 Post(s)
    5958 Post(s)
    Usually bottoming out means sending a lot of power to it.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  18. #15
    Jeffdachef's Avatar
    Feb 2013
    15,836
    235 Post(s)
    7703 Post(s)
    It doesnt sound like its actually mechanically bottoming out since op is not even playing low. Sounds like a weak dirty signal causing an overload of distortion. Had an issue like that with a guy swapping out a kenwood single din for a power acoustik double din and he lost soo much output and his sub sounded wierd when pushed.
