+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 56 of 56
Reload Thread: Sundown Audio SA12 bottoming out
  1. #46
    BRZ's Avatar
    BRZ
    BRZ is offline Fart Knocker
    May 2014
    NJ
    91
    31 Post(s)
    Re: Sundown Audio SA12 bottoming out
    I have a dremel and like DIY projects, but if there are no negative impacts in letting it ride like this then I'm not going to bother. Do you know exactly what the internal issue is that is causing it to make this noise and need a re-cone? Is it possible my ground is bad as Jeff suggested? Is there anything I can inspect without taking the speaker apart?
  2. #47
    Jeffdachef's Avatar
    Jeffdachef is online now 160 db farts n sharts
    Feb 2013
    South Coast Metro, CA
    12,311
    110 Post(s)
    5470 Post(s)
    Quote Originally Posted by BRZ View Post
    cant inspect anything. Its just an issue that happened to me back then. same noise as you, on the higher frequencies it was prevalent but low frequencies had no issues. It was doing that with every sub i put in along with every amp i put in. So i traced it back to some resistance at the grounds and redid the ground tightly. Issue was gone for all woofers.
    09 Sienna Subs : NOTHING Sub amp: NOTHING
    Headunit: Pioneer 80PRS Mids/Highs amp: PPI 900.4
    Front stage: 3 way active front stage with Massive Audio CKX tweets, alpine type R 6x9 midrange in doors + Crescendo PWX 10s in the kick
    320 amp Singer alt. 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  3. #48
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    I'll take a look at the ground since that's obviously the easiest to check. Did your noise spring up out of no where, or was it there since you first did your install?
  4. #49
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Tenn
    757
    15 Post(s)
    445 Post(s)
    No a bad ground won't make it sound like that.
  5. #50
    staan's Avatar
    staan is offline Senior VIP Member
    May 2016
    new orleans, la
    246
    168 Post(s)
    using viper4android with a u-ish shaped curve.
    I'm pretty sure this is the issue check and see how much of a db range that eq has and back down the low freqs
    some crappy eq's can have 12 or more db's of adjustment and that much will def cause clipping and could bottom out that sub in a sealed box
  6. #51
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Thanks for the feedback staan, this issue did start shortly after updating my HU firmware that has this Viper4Android crap on it. Im going to revert back to an old version and see what happens.
  7. #52
    Based's Avatar
    Based is offline CarAudio.com Elite
    Mar 2014
    Louisiana
    853
    1 Post(s)
    406 Post(s)
    After box rise and the fact that your amp isnt 100% efficient, your sub is probably seeing around 400watts.
  8. #53
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    Quote Originally Posted by Based View Post
    Ok...what point are you making?
  9. #54
    Based's Avatar
    Mar 2014
    Louisiana
    853
    1 Post(s)
    406 Post(s)
    I only read the OP. I'm just saying it's not that it's getting too much power
  10. #55
    BRZ's Avatar
    BRZ
    May 2014
    NJ
    91
    31 Post(s)
    I switched firmwares and eliminated the Viper4Android/ViperFX module and the issue still exists. I think I'm going to live with it until the sub blows. Like I said, I can only hear this when I'm sitting in front of the sub setting the gain or something -- when its playing while in the trunk I cannot hear it. It ***** but at least it works still.
  11. #56
    shredder1's Avatar
    shredder1 is offline Member
    Dec 2013
    Phoenix, AZ
    48
    1 Post(s)
    17 Post(s)
    Mystery rattle, Cheap head and quality woofer... what a mess! since you've ruled out the box and feel that your HU is fine... its probably the woofer... my son's RE *** 10 did the exact same thing and I noticed a tinsel lead that was separated from the cone where it passes through... Very hard to spot visually... but once I started moving the cone manually to feel if there was coil rub I noticed that the factory glue was separated at the pass thru location on the cone... He's very hard on woofers as he loves to show his friends the excursion of these subs even though at those freqs they are out of the range for a couple of 10's (20-25 hz is what he tries to play) He played it so long like this that he loosened the tinsel and unraveled the coil shorting out my hand-me-down 500s Fosgate! Kids... live and learn... anyways be very careful when you inspect the sub as this rattle does sound like something similar... I bought a L7 10" rattling once and fixed it quick because the cone is a 2 piece assembly and the front had separated from the rear... A little glue and "Like magic" it was fixed... Could be an easy fix... could be a bear... Good luck
+ Reply to Thread
