Results 1 to 3 of 3
Reload Thread: XXX and Box Situation
    fury's Avatar
    fury is offline Member
    Jun 2004
    Indiana
    65
    Well, it's finished. The box for my 15" xxx is complete.. or mostly. It ended up about 4.2 ft^3 after port displacement, tuned to roughly 32hz. The hole for the sub has not been cut, it was sealed with screws and liquid nails used together. the edges of the port were rounded on the inside(I did slack on getting rid of all 90s in the port though). The box is braced with a plus sign shape of bracing using 1" diameter wooden dowels. The dowels are not actually touching, but are near each other. The box is EXTREMELY sturdy and protected. The box is **** near perfect in my eyes. I think we measured everything and checked it twice, except for.. well one small issue. The trunk opening isn't big enough to get the box in without removing the spare tire and jack. Even then, it is VERY tricky and involves some jamming to get it in the trunk. Then the spare/jack cannot be replaced. Well needless to say I can't have this.. luckily the xxx has not been ordered yet..
    I have to make a choice now, seeing as that box is clearly too large for my trunk (my dad says I can't leave the spare out--I do agree though.. I should have it). I will not put it on my back seat. I don't really know what to do.
    Heres what I've come to..
    1) Sell this box, make a sealed box for a 15" xxx (re recommends 2 cubes).
    2) Sell this box, make a ported box for a 12" xxx (re recommends 2.1 cubes.. I'm guessing after port displacement)
    3) Figure out a way to get the box into the trunk without removing my spare(I don't see it happening)
    Thoughts opinions? Which situation might work better of 1 and 2. I'm more for LOUD, but with some decent SQ.. and if you have a way to do 3 let me know
    BTW Car is a 99 Grand Prix GT if you're wondering.
    Bigrick31's Avatar
    Bigrick31 is offline Carpe Diem
    Mar 2004
    Mid*Cal
    3,557
    Re: XXX and Box Situation
    i would say get a 12xxx in a ported box ported is louder than sealed a 12xxx in a ported box should be a lot louder than a 15xxx in a sealed
    Strecker25's Avatar
    Strecker25 is offline Better than everyone
    Feb 2004
    Rochester, NY
    30
    989
    we had the same problem when installing 2 10s in a sealed box in my buddys mustang, it was a nightmare but we did get it in...the solution was taking out the back seats and sliding it in that way then replacing the seats. His spare is very difficult to get out but at least its still in there. Not sure if this is possible but just a suggestion
    Panasonic CQ-HR1003U
    Twin Diamond Audio M6 12D4's
    3.2Ft^3 @33hz
    Viper Audio d1200.1
    Diamond Audio M651 5.25" components
    Profile Clarus CL800
    200amp alt, big3
    2 Gallons of eDead v3 ( Group Buy )
    40sqft eDead V1se
    20sqft Dynamat extreme
    Pictures of the setup
    Video of the M6's
    All in a 94 Lumina
  1. Box for a 15" XXX
    By fury in forum Enclosure Design & Construction Help
    Last Post: 07-06-2004, 08:35 PM
  2. RE XXX 18 in a Sealed Box!!!!!!
    By james33440 in forum Subwoofers
    Last Post: 06-04-2004, 09:59 PM
  3. How big of a box for 12" XXX?
    By Another Device in forum Enclosure Design & Construction Help
    Last Post: 03-31-2004, 11:01 AM
  4. XXX just in trunk no box? help plz
    By w00t w00t in forum Enclosure Design & Construction Help
    Last Post: 03-05-2004, 04:56 PM
  5. Sealed box for XXX 12
    By CELLERBR in forum Enclosure Design & Construction Help
    Last Post: 12-27-2003, 01:45 PM
