Results 1 to 4 of 4
Reload Thread: Help with box for beginner
    paulh's Avatar
    paulh is offline Junior Member
    Mar 2004
    London, England
    Hi, bit of a total novice here, but all the same i've decided to make my own MDF stealth shelf which will have some 6 x 9s on the underside, and cover with acoustic cloth. Making a good job will be the easy bit, I know how to use MDF etc, and I already have all the materials from a company that makes aftermarket stealth shelves, but doesn't do my model of car.
    I also want to mount a sub onto to the underside of this shelf, and enclose it. Reason for this is so that the trunk space still has maxmium usage, and when covered with carpet to match the trunk it will be hard to find should someone break in the trunk.
    I need help in two areas.
    First, maybe an easy one. If I make a box from 3/4" MDF, is there any point adding any sound damping material to this? (I have installed dynamat type stuff throughout the car)?
    Second, not so simple I would guess: What about the shape of this box, and how is it going to affect sound?
    To clarify my plans: The rear parcel shelf is about 4" x 3", quite a huge thing. It will be re-made from 3/4" MDF and have three holes cut for a pair of 6 x9s, and 12" sub. That will be covered in acoustic cloth so that the holes can't be seen. The 6 x 9s will be mounted underneath, and then a sealed box will be made for the sub which is then mounted also underneath. I have a special shallow sub which means I want to keep the box shallow, so it will be more like a 'tray'. So, it could be 3 x 3 ft, but only 6-9" high.
    Is this going to work? Should it be ported? Should I throw wadding in?
    Does it matter what shape it is? Is space just space?
    How much space should I be aiming for? As much space as possible? (Sub = High power handling capacity of 600 watts, RMS power 200 watts, High sound pressure level of 90 dB (2.83 V/m).
    Should I get the box to incorporate the 6 x 9s on either side?
    I'm not after best solution ever, I'm after best solution with the box mounted as I have explained, on the shelf, because the way I use my trunk dictates this, so sorry if it will be a bit of a crap question to answer, but....
    Any suggestions really appreciated.
    -p
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Re: Help with box for beginner
    Quote Originally Posted by paulh
    NO. You should have to.
    Shape does not matter as long as the box is well built and air tight.
    In should work. Porting it is up to you. It depends on how you want it to sound and if you box is large enough to accomidate a port. You have to figure that the port will take up space inside you box. As far as wadding goes, I assume you talking about poly-fil, it wouldn't hurt to add some, espicially if it's a sealed box.
    Answered above.
    You should try and give the sub it's RMS rated power. If you match it up build the box to the recommended size. If you underpower it, go a little larger, like .5cu', and if you over power it you can go a little smaller.
    No. over time you will damage the 6x9's due to the air movement of the sub.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    paulh's Avatar
    Mar 2004
    London, England
    GREAT!!! Thanks, that was easy.
    Only two things are not clear;
    1) On my question about sound damping on the box; your reply seems to say both No, and then Yes I should. Please clarify.
    2) Second, how do work out or find the recommended size (in cubic cm I presume) for my box?
    And another quicky; what sound difference does a port give?
    ;-P
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    I should have said "shouldn't" and not "should"...sorry about that.
    [quote=paulh}2) Second, how do work out or find the recommended size (in cubic cm I presume) for my box?[/quote]
    The manufatcure should have a recommended box size.
    ;-P
    A port allows you to get the lower notes, and in some cases get louder, more easily than a sealed box. Especially if your working with a small box.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  1. box is finshed (pics)
    By bass maniak in forum General Discussion
    Last Post: 11-30-2005, 09:17 AM
  2. bigger box = lower bass???
    By infinity1412 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2004, 01:01 PM
  3. A bigger box?
    By xSomeguyx in forum Enclosure Design & Construction Help
    Last Post: 03-02-2004, 12:52 PM
  4. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  5. basic box questions
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-22-2003, 05:04 AM
