Results 1 to 15 of 15
Reload Thread: Design Needed for American Bass XFL 1522 in 3.5 Cubic Ft @ 30 Hz Enclosure Slot Port
    nyoc's Avatar
    nyoc is offline Member
    Sep 2010
    Toledo, OH
    81
    6 Post(s)
    Vehicle : 2006 Dodge Stratus
    Location in the vehicle: Trunk
    Space available (Length x Width x Height): 22" x 36" x 22"
    Subwoofer make and model: American Bass XFL 1522
    Subwoofer Size: 15"
    Number of Subwoofers: 1
    Type of Port (Kerfed, Slot, Aero, etc.): Slot
    What type of music do you like?: Rap
    Is your goal SPL or Everyday Music?: A little of both
    Tuning Freq (Hz): 30
    Volume : 3.5 cubic feet
    Questions: Thinking about doing sub up port back
    I will be using 3/4" MDF with a double baffle. I would also like to get a cut sheet if this isn't asking too much. I tried doing this on my own with WinISD and a couple of other programs but I can't seem to get it just right. If you have any questions, please ask here or pm me please. I will pushing his with a Skar 800.1
    Androidaaron34's Avatar
    Androidaaron34 is offline Junior Member
    May 2016
    Romulus Mi
    17
    3 Post(s)
    Re: Design Needed for American Bass XFL 1522 in 3.5 Cubic Ft @ 30 Hz Enclosure Slot P
    I can tell you what I did that's just really really close to your trunk build but it is a aeroport round Port design for 2 Sundowns
    I would go 35 wide 21 and a half deep and 16 High use a 6 by 10 aeroport from Parts Express it's tuned and exactly at 33 Hertz and you're right at 3.98 cubic feet
    That's Precision Dimensions providing your subs will require between 1.75 and 2 cubic feet each you will be slamming with that specs don't worry about the hassles of vented ports just go with a simple aeroport design cutout of 8 1/4 Quarter inch hole between the subwoofer cutouts after you center the subs Slide the port in screw it in
    May 2016
    Romulus Mi
    17
    3 Post(s)
    Just realize you're using One 15" it should still work if that's sub requires between 1.75 and 2 cubic feet ported and you can point the sub up and Port back put the port to the very far right and put the sub to the left. It's all still relevant regardless of 2 12" or 1 15"
    All that matters is Port dimensions lining up with the SUB port requirements and cubic feet of box if you build a box to those specs you'll be right at 3.98 cubic feet just make sure that the sub requirements give you at least between 3.5 and 4 cubic feet Max
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    412 Post(s)
    2 Thread(s)
    973 Post(s)
    Quote Originally Posted by nyoc View Post
    Subwoofer Size: 15"
    I can hook you up with a cutsheet. Pm me.
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
  5. Likes Savackz liked this post
  6. #5
    nyoc's Avatar
    Sep 2010
    Toledo, OH
    81
    6 Post(s)
    Thanks, from what I have seen it requires 3.5 cubic feet. Someone has actually given me a very nice design. Thanks for the input.
  7. #6
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I can make you a design if you still need one.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  8. #7
    nyoc's Avatar
    Sep 2010
    Toledo, OH
    81
    6 Post(s)
    I'm open to other options, please let me know what you would come up with. Thanks
  9. #8
    CSCStang's Avatar
    Mar 2014
    OC, Ca
    2,971
    412 Post(s)
    2 Thread(s)
    973 Post(s)
    Pms are full. I looked at the design, looks great. I say build it.
  10. #9
    The_Dealer's Avatar
    The_Dealer is offline Senior VIP Member
    May 2014
    Macon Ga
    483
    14 Post(s)
    151 Post(s)
    This is what I recommended on caco
    Sent from my SM-G900A using Tapatalk
  11. #10
    Basshead92's Avatar
    Basshead92 is offline Junior Member
    Nov 2016
    Columbia,SC
    1 Post(s)
    I'm a noob to the box building with same design could I shorten the width to 32 and make the depth a little deeper and still have the same specs my measurements are 32 Wide 26 Depth 16 Height max need help understanding and I really wanted to be tuned a 32hz
  12. #11
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    13,404
    68 Post(s)
    2 Thread(s)
    5547 Post(s)
    i personally think 3.5 is on the small side. Id do closer to 4. tuning to 32 will give you good extension dont expect a TON of output.
    i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
  13. #12
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Quote Originally Posted by Basshead92 View Post
    Also depends what kind of music you listen to. Anywhere from 30-35 Hz. is the ideal tuning.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  14. #13
    Basshead92's Avatar
    Nov 2016
    Columbia,SC
    1 Post(s)
    Rap music so 4 cu would better in my case
  15. #14
    Basshead92's Avatar
    Nov 2016
    Columbia,SC
    1 Post(s)
    I'm running a hifonics 2000.1D to it BTW at 2ohm which is about 1400 with the sub firing up port the the rear of the car
  16. #15
    Cm_low's Avatar
    Cm_low is offline Member
    Dec 2016
    Arnold, MO
    114
    30 Post(s)
    How did this setup work for you? I am about to build for the same sub and be running approximately the same power but in a 2012 chevy cruze. I was going to do sub firing rear though instead of up. I was toying with the idea to face upwards but read a few different places that it would cause more rattling with little benefit.
  1. Box Dimensions for American Bass XFL?!
    By DJSlowfets in forum Enclosure Design & Construction Help
    Last Post: 03-19-2015, 10:19 PM
  2. Design Questions for 2X 12" Pioneer TS-W3002D4 in 2.4 Cubic Ft @ 31 Hz Enclosure
    By DeWize1 in forum Enclosure Design & Construction Help
    Last Post: 01-03-2015, 10:54 AM
  3. American Bass XFL's in a Sealed Enclosure??
    By FadedSpy in forum Enclosure Design & Construction Help
    Last Post: 10-29-2014, 10:05 PM
  4. Enclosure design needed for 2 - SWR-12D4's in a Dodge Magnum
    By focused313 in forum Enclosure Design & Construction Help
    Last Post: 11-21-2013, 09:17 AM
Tags for this Thread
