I'm building a sealed box to house 2 IDQ12D4V.2's. The normal sealed box volume for these subs of the IDQ site is .85 cu. ft., which is the volume I'm looking for. I'm building a trapezoidal box with these dimensions:
slanted wall: 15" tall
top: 4.818"
bottom: 8.798"
rear wall: 14.489"
depth: 14.836" per sub
angle of tilt: 75 degrees (15 off vertical)
I know these figures are insanely precise but I want to be as precise as possible. I have a few questions. First, would it be better to seperate the two subwoofer chambers, with each having a volume of .85 cu ft, or to make one large chamber for both subs with a volume of 1.7 cu ft?
My other question is regarding the material. I know I'm going to build it out of MDF, but I'm thinking of going with two sheets of 3/8 inch MDF with a layer of dynamat sandwiched in the middle. I'm only going to have my current car for 2 more months, so I don't think it's worth dynamatting the interior. The interior SA of the box is 10.95 sq. ft.
Is it a good idea to use the 2 sheet and dynamat construction, or will this just be a waste of dynamat?
Also, for this project, would it be better to use ordinary dynamat or dynamat xtreme, or something more obscure like dynaliner or extremeliner?
Register To Reply
Bookmarks
