making my box look better
i was thinking about getting a pair of those apc license plate led lights and bolting them inside my enclosure adjacent to the 3" pvc ports son when you pop the trunk the ports glow inside but i don't know if the light would spread out enough to give the desired effect like a neon light would. (this would be cheaper, easier to install and 2 little leds would rob less current from my system than neon tubes.
What would be the best way to vinyl wrap the enclosure leaving the front baffle uncovered,(want to stain that black ash to resemble a home audio enclosure)
how could i cut some brushed aluminum look abs sheets (the ones from selectproducts.com) in rings the thickness of the walls of the pvc ports.
Car: '97 Crown Victoria P71
HU: Pioneer Avic X710BT
Front stage: want bravox CS603CF
Front stage amp: want powerbass XTA 2240
Substage: 15" FI BL fully loaded in 3.5 cubes @33hz firing through rear deck.
Substage amp: Powerbass XTA 1500D
Bookmarks
