Results 1 to 8 of 8
Reload Thread: box building
    2001KX's Avatar
    2001KX is offline Member
    Jun 2004
    pa
    41
    57
    box building
    does it matter how you put the joints together(see pic below)?
    Jesse98's Avatar
    Jesse98 is offline Senior VIP Member
    Jun 2004
    Clyde, NC
    32
    189
    Re: box building
    no dont see why it should.
    yamaha326's Avatar
    yamaha326 is offline livin loud
    Dec 2003
    Texas
    938
    Re: box building
    just as long as it seals
    1994 GMC SIERRA ext cab on 22's
    headunit.........p.o.s.sony
    speakers.......4 kenwood 4x6
    amp............1 hifonics bx2006i
    subs........... 2 12"kicker L7
    box...........ported 2.25 cu ft each tuned to 35hz
    wiring....scoshe
    too lazy..but need big 3 done!!!
    15" kicker cvr
    ported 3.5 cu ft sealed----------------------------------------------------------------
    aim--ymracing43
    [email protected]
    supraman1379's Avatar
    supraman1379 is offline Lifted 03 HEMI
    Mar 2004
    Ocala, Fl
    30
    3,192
    3 Post(s)
    Re: box building
    Make sure you use wood glue. and i found it best to use a staple gun with 1 1/4" staples, cause the wood doesnt split as easy. but if screws are all you got....then use them but be careful not to split the wood
    Ride: 2003 Dodge Ram 1500 HEMI
    Color: Black
    Head Unit: Alpine IVA D310
    Speaker Amp: JL Audio e4300
    Front Speakers: Stock 6x9s
    Rear Speakers: Stock
    Sub Amp: Bostwick 1100 (1100 RMS @ 1ohm)
    Subs : (1) Kicker Shallow Mount
    Enclosure: Prefab Kicker box (came with sub)
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Re: box building
    Quote Originally Posted by supraman1379
    Drill pilot holes and countersink the heads of the screws, always works fine for me. But yes, USE WOOD GLUE!!
    2001KX's Avatar
    Jun 2004
    pa
    41
    57
    Re: box building
    ok thanks for the info guys
    Jesse98's Avatar
    Jun 2004
    Clyde, NC
    32
    189
    Re: box building
    so why wood glue? I always use liquid nails, or do you mean stuff like thats ok to?
    Moe Lester's Avatar
    Dec 2003
    Houston, TX
    31
    3,614
    Re: box building
    Quote Originally Posted by Jesse98
    Anything that will make a very very strong + airtight bond is fine.
  1. box building
    By CalSpecBoy in forum Enclosure Design & Construction Help
    Last Post: 04-15-2004, 01:00 PM
  2. im a newb to box building... help me out
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 02-29-2004, 11:54 AM
  3. SQ box building hints/tips/primer?
    By Zylo in forum Enclosure Design & Construction Help
    Last Post: 02-03-2004, 11:23 AM
  4. i am the box building retard
    By FuNKieJuNK in forum Enclosure Design & Construction Help
    Last Post: 01-04-2004, 11:46 PM
  5. better box building...
    Last Post: 12-21-2003, 01:12 PM
