Results 1 to 3 of 3
Reload Thread: do walls help....
    aphinney's Avatar
    aphinney is offline CarAudio.com Elite
    Nov 2002
    in my house
    28
    828
    do walls help....
    ok..my friend and i just bought an 88 astro van and we are goin to stick 2 18" solo x subs in...and we are cementing the walls and welding the doors stuff and takin all windows out...and dynamat everything..and we wanted to know if we built a wall if it would be louder then just havin just an enclosure.??
    TEAM AUDIOHYPE
    TEAM REVOLUTION
    TEAM KINETIK
    TEAM HO ALTS
    TEAM AUDIOHYPE
    3x world champs
    3x world record holders
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,485
    Re: do walls help....
    most likely yes becuz that would make the cabin space in the van very small. 2 18"s moving air in a small space would be pretty loud with the right port tuning(size), wall, and a good size amount of power.
    i'm thinking 4000+ on each sub. could be a costy project but rewarding.
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
    03rejo's Avatar
    03rejo is offline Junior Member
    Feb 2004
    Green Bay, WI
    28
    20
    if you make your wall enclosure too big for the recommended size it will actually just lose sound at an alarming rate, but as marshall said the smaller the cabin size the better for SPL, so you could make a wall and make some appropriately sized boxes with it and you would have the best possible spl that way. Power is not so much a factor though once you get past 150db, but is more about the number of subs you've got. To increase 1db when you are over 150 you need to effectively double the power you are currently running to your subs. by adding another subwoofer however, you can see an increase of 3 - 14db.
    I just upgraded my system twice, i'd had 2 12" hcca's running on a 1001BD rockford amp and it was very loud, then upgraded to the hcca 2100 amp running 2300wattsRMS and it only increased 1.6db's, from 151.2 to 152.8 and now I just added to more 12" hcca's and i'm hitting 164.8 still running the same hcca2100 to all 4 subs.
  1. internal walls
    By saywhat? in forum Enclosure Design & Construction Help
    Last Post: 04-26-2004, 06:59 PM
  2. wall's
    By dbhittin in forum Enclosure Design & Construction Help
    Last Post: 01-20-2004, 11:36 AM
