Results 1 to 4 of 4
Reload Thread: Shared space or seperated space for an enclosure?
    Ne1's Avatar
    Ne1
    Ne1 is offline MacDaddy lookin for the $
    Jan 2004
    Tampa, Fl
    46
    225
    3 Post(s)
    I have recently gotten a 1996 328is, and after doing the measuerments in the trunk I have come up with a box that will yield roughly 1.5 cubic feet per sub (2 subs) in a seperate chamber set up, or 3 cubic feet of shared space. Now my question is, which would sound better? The shared space, or keeping the subs seperated? I'm going for sq and not spl on this, so the answer would relate more along those lines.
    The subs are 2 12" mmats pro series btw.
    Thanks!
    Jesse98's Avatar
    Jesse98 is offline Senior VIP Member
    Jun 2004
    Clyde, NC
    32
    189
    Re: Shared space or seperated space for an enclosure?
    normally you want seperate chambers, in one chamber the subs kinda work against each other, so Id say seperate chambers, not sure wich it effects more though sq or spl.
    supraman1379's Avatar
    supraman1379 is offline Lifted 03 HEMI
    Mar 2004
    Ocala, Fl
    30
    3,192
    3 Post(s)
    i would put them in sperate chambers i think they sound better. It makes it like the subs are tryin to cancel each other out if its in the same chamber. or at least thats what it sounds like to me
    Ride: 2003 Dodge Ram 1500 HEMI
    Color: Black
    Head Unit: Alpine IVA D310
    Speaker Amp: JL Audio e4300
    Front Speakers: Stock 6x9s
    Rear Speakers: Stock
    Sub Amp: Bostwick 1100 (1100 RMS @ 1ohm)
    Subs : (1) Kicker Shallow Mount
    Enclosure: Prefab Kicker box (came with sub)
    Jesse98's Avatar
    Jun 2004
    Clyde, NC
    32
    189
    Quote Originally Posted by Jmac
    Go with separate chambers ... It doesn't make much of a sound quality difference if done properly. Using a separation acts as a brace, for one. Two, it allows you to run just one sub. With a shared chamber, you NEED two subs.
    If I wasnt lazy id dig up proof, but I think you are wrong, would like to find actual proof that shows what the waves inside the box do but I am lazy for now so if anyone else is up to it go for it. I think it does make a difference esecially the smaller box you have.
  1. enclosure vs. air space HELP
    By boomnbreeze in forum General Discussion
    Last Post: 03-24-2004, 09:35 PM
  2. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  3. Two 12's in shared or seperated sealed chamber?
    By Tragedy116 in forum Subwoofers
    Last Post: 01-15-2004, 10:21 PM
