Results 1 to 12 of 12
Reload Thread: Fill in the blank
    MakkMar10's Avatar
    MakkMar10 is offline Bangin on a Budget
    Mar 2014
    SoCal
    411
    189 Post(s)
    Fill in the blank
    I have 45x40 floor space behind my 2nd row. 45" wheel well to well an 40" from back of 2nd row seat to rear gate. I kno I need to be a few inches from rear gate, so I figure 45x34 an I want to go 15" high. So is 45x34x15 rite or is there sum special ratio that needs to be used? I most likely will have my box built, it's jus 3-4 months down the way. An if I can get enough info by then I may make an attempt my self.
    HU: Pioneer avh-x4700bs
    FrntS: 4 Infinity Kappa 682.11cf
    SubS: HDC3 18 in 6cu at 35Hz
    Amps: zxs1500.1 and zx350.4
    Elec: 2 Diehard Platinum g65's
    130a stock alt with 0g Big 3
    Cables: 0ga, 4ga, 8ga, 12ga SHCA
    big scott's Avatar
    big scott is online now blazin low, and loud
    Apr 2014
    edgewood, md
    43
    3,468
    20 Post(s)
    1103 Post(s)
    Re: Fill in the blank
    you need to pick a sub/s then figure out what size box they ( subs ) need.
    88 s10 blazer 2door 6/6 drop triple black.
    pioneer 80prs- ppi 88r DSP - rca 7" tablet.
    8-sq super tweeters on ( us acoustics barbara ann 4ch) ( "amp 1" )
    4-sq pro 6.5 on ( us acoustics Barbara Ann 4ch) ( "amp 2" )
    4- 8"dayton's on ( aq 200.2 )
    sq hdc3 15" d2, tuned to 34hz on ( ppi ba7000.1 ) (( doing 4 sq hds212 ))
    all knu wire/rca, big 4,, db 200amp alt/100amp alt.
    yellow top under hood--- 7- amg battery's in back. 40sq ft of q-mat.
    plans.... (2)sq-2200,,(2)sq-120-4--3-240amp alt's. knu dampener
    CHEVY RULES..............
    Umbra's Avatar
    Umbra is offline Hobbyist & CA Tenderfoot
    Sep 2013
    Long Island, NY
    24
    665
    206 Post(s)
    big scott's got the right idea. You build the box around the sub - at least it'd be easier to make a match that way. Figure out what subs you want, then figure out how much volume they each need for the type of enclosure you want to build, then build the box. There's no magic ratio, so long as it's not ten feet long by six inches high or something like that you should be good.
    My Minivan Setup:
    • Head Unit: Kenwood KDC-BT852HD
    • Speakers: 4 Pioneer TS-D6902R coaxials on 2 SONY Xplod XM-1002HXs (The old school, made in Japan ones), ~100W RMS @ 4Ω to each
    • Subwoofers: 2 Rockford Fosgate P210S8 10"s in a custom 2.75ft³ ported enclosure tuned to 35Hz on a Kenwood KAC-9103D, ~400W RMS @ 4Ω to the pair
    MakkMar10's Avatar
    Mar 2014
    SoCal
    411
    189 Post(s)
    Quote Originally Posted by big scott View Post
    Quote Originally Posted by Umbra View Post
    2 SoundQubed HDS315's....so how far back from the gate, 6" is enough?
    Umbra's Avatar
    Sep 2013
    Long Island, NY
    24
    665
    206 Post(s)
    That sounds right, but I don't run massive boxes like that, so someone's should confirm that number.
    My Minivan Setup:
    supra1987's Avatar
    supra1987 is offline Senior VIP Member
    Oct 2013
    rhode island
    234
    69 Post(s)
    Quote Originally Posted by MakkMar10 View Post
    I think 6 would be the minimum.usually the same width as your port from what I've seen.
  7. Likes MakkMar10 liked this post
  8. #7
    csu87's Avatar
    csu87 is offline CarAudio.com Veteran
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    6 is where I had the best luck firing into a back gate. but since you didn't give us a vehicle...
    Current - BMW 335xi SQ Build w/ IA and Sundown
    Retired - GMC Jimmy SUBS: 2 12" Aqs SUB AMP: 1 AQ 3500.1 Loudest TL 155.1
    Feedback: MakeshiftAudio, woofercooker, vitveet, jonesy, 2000gator, KickerRex, mathewo, Matt2105, sicaudio, kshutte, coma-toast, RAB, matt2105, jusbloud and more that i cant remember.
  9. #8
    MakkMar10's Avatar
    Mar 2014
    SoCal
    411
    189 Post(s)
    Quote Originally Posted by csu87 View Post
    2002 Ford Explorer....Did u have similar dimensions?
  10. #9
    csu87's Avatar
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    I had a GMC Jimmy and 6" was the magical number for me. best way to find out is trial and error. or shoot for 6" and go from there.
    as far as your box dimensions, that is up to the subs and the amount of power to them. for 2 15s, id shoot for 6.5-8cuft if it was me.
  11. #10
    MakkMar10's Avatar
    Mar 2014
    SoCal
    411
    189 Post(s)
    I calculate 10cu net (45x32x15).... So smaller box u think? Ima start with a kicker zx1500 @ 2ohm thn with in a few months upgrade to a Q2200d @ .5ohm. After extra battery an HO alt. Am I goin about ths rite?
  12. #11
    csu87's Avatar
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    you have to factor in the port displacement and the subs displacement into your net box size. bigger could be better with the kicker amp, but with the sq2200, you are going to want to be a tad smaller to control the subs better.
  13. #12
    MakkMar10's Avatar
    Mar 2014
    SoCal
    411
    189 Post(s)
    I took the overall demo's times .2 an got a solid 10cu....So u wudnt recommend an amp swap with tht size box? Well how bout 8.5 - 9cu?
  1. ***ATTENTION*** box designers, fill in the blank on my box design
    By slapmaster in forum Enclosure Design & Construction Help
    Last Post: 11-08-2008, 06:37 PM
  2. Upgrade anything? Fill in the holes in my setup
    By zachzchw in forum General Discussion
    Last Post: 05-11-2006, 03:41 PM
