Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Help designing a box for a soundqubed 15"
  1. #16
    shauncox26's Avatar
    shauncox26 is offline CarAudio.com Elite
    May 2013
    oxford ms
    1,694
    10 Post(s)
    606 Post(s)
    Re: Help designing a box for a soundqubed 15"
    well if it was me i would save that hundred and get another 12. its a pretty big step down from a 15 to a 12. but u could save alot of space going that route and that's not saying the 1 12 won't get u were u want. but once u hear 1 ur gonna want 2 then 4 so on and so forth. this hobby is worse than crack.
  2. Likes Spl4200 liked this post
  3. #17
    bassinmytruck's Avatar
    bassinmytruck is offline Junior Member
    Jan 2014
    Wichita, KS
    22
    9 Post(s)
    Quote Originally Posted by shauncox26 View Post
    haha I know what your sayen man. Well thanks for all the advice!!
  4. #18
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,096
    15
    38 Post(s)
    4134 Post(s)
    Quote Originally Posted by bassinmytruck View Post
    Sorry if I am being stupid or something but this is my first box! So ur saying I cant change the port area? and 3.5 cubes isn't the lowest recommended box volume, 3 cubes is
    I'm saying a larger box will get you more output and you should use the manufacturer recommended specs for volume and port size. They don't just pull those box specs out of their arse, they print them because that's what those woofers are designed to use as an enclosure.
  1. Need help designing a box for TWO Fi BL 15's
    By teenagebasshead in forum Enclosure Design & Construction Help
    Last Post: 06-09-2014, 03:49 PM
  2. Help designing a box for 3 15s
    By justice66 in forum Enclosure Design & Construction Help
    Last Post: 12-05-2012, 08:02 PM
  3. Need Help Designing a Box for 2 15" Type R
    By jlmannsg21 in forum Enclosure Design & Construction Help
    Last Post: 08-28-2007, 10:33 PM
  4. Need Help w/ designing a box for a MT 15
    By sj_grendel in forum Enclosure Design & Construction Help
    Last Post: 12-31-2005, 11:41 PM
  5. Can someone help me design a box for a single 15" Brahma?
    By qwkracer in forum Enclosure Design & Construction Help
    Last Post: 04-13-2004, 09:48 PM
Tags for this Thread
