Results 1 to 11 of 11
Reload Thread: Custom Center Console Ported Box Help PICS
    PKP80's Avatar
    PKP80 is offline Junior Member
    Jul 2014
    Los Angeles
    1 Post(s)
    First post and it's a good sized one. I am no stranger to sub boxes and fiberglass. Here is the run down:
    1. Made an integrated center console sub box to fit an 8" sub and I want it to thump so I made it as a ported box. I do not have a lot of familiarity working with vented enclosures.
    2. You can see that the box is a square with the bottom back corner forty-fived off to fit to the car body.
    3. Port: Precision Port, 2" diameter and 8 5/8" from lip to lip in length
    4. Sub: Infinity Reference Ref860w SVC
    5. The sub sits 2.5" from the bottom edge of the 45deg up slope in the box
    6. I have estimated the Volume of the box at .68ft3 +/- .05ft3
    7. I have installed the sub and port to test and I am getting a lot of Air movement sound instead of clean deep bass hits.
    I am thinking it maybe a sub issue and want to change sub to the shallower JBL GTO804.
    You can see all my measurements in the drawing photos and PLEASE ask any questions you may have the sub is firing towards the rear seats and the back of the cab is fairly open to the elements.
    THANKS IN ADVANCE
    Sammi
    Attached Thumbnails Attached Thumbnails Custom Center Console Ported Box Help  PICS-20140630_184527.jpg   Custom Center Console Ported Box Help  PICS-20140630_184518.jpg   Custom Center Console Ported Box Help  PICS-20140630_184555.jpg   Custom Center Console Ported Box Help  PICS-20140630_184753.jpg   Custom Center Console Ported Box Help  PICS-20140630_212014.jpg
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    Re: Custom Center Console Ported Box Help PICS
    I'd really appreciate any input regarding this matter.
    anger's Avatar
    anger is offline Senior VIP Member
    Aug 2012
    Oxnard, CA
    311
    7 Post(s)
    77 Post(s)
    My guess is (and this is in fact a guess...I don't have enough knowledge to give a definite solution) that it's an issue with the enclosure. Maybe not enough volume or not enough port area. You may want to try it sealed and see how it sounds. I don't think that's enough space for a decent vented enclosure, but I could be wrong. I'd wait for some veteran advice. In the meantime, you could seal off the port opening and try it that way.
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    Might a Shallower depth sub work better?
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    Still waiting on veteran advise por favor
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    Would a shallow mount woofer make any difference?
    Joseph7195's Avatar
    Joseph7195 is online now Walkin Tall
    May 2011
    Saltillo, Mississippi, United States
    38
    1,467
    385 Post(s)
    I Use a center console sub enclosure, and the biggest problem I had was the sub was too close to me, and I can really hear the sub movement. It's just not enough room for the bass propagate. When I switched the sub enclosure from my Ram 1500 console, and into my wives rear SUV compartment (same enclosure), the bass was much more pronounced, full and louder! Changing where the sub is located on your enclosure (firing it down) might be a good thing to try.
    Quote Originally Posted by adulbrich View Post
    We don't have food stamps on the east side. Its called a link card. Man, the grocery is packed on the first of da month. I shit you not, a homie got stabbed over a can of soup.
    adulbrich's Avatar
    adulbrich is offline Lock up your daughters!
    May 2014
    Ames, Iowa
    20
    13,836
    119 Post(s)
    6118 Post(s)
    A sub that is more shallow will NOT solve your problem. The enclosure is lacking enough volume and/or port area. If you are hearing a lot of air movement (port noise), you need a larger port. With such a small enclosure, don't get your hopes up as far as output.
    I had an SA8V2 in a ported box (less than .5 cubes) with a 2" aeroport because of space reasons. To compensate for the small volume and port area, I made the port extremely long. It was slightly less than 5 feet in length, lol. It got really low too
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  9. #9
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    Thanks for the Replies:
    My reasoning behind a shallower sub is that by using one, the space taken up by the sub would be less and the magnet would not be so close to the back of the box (about 1" of space now). The box currently has ~.68 cubic ft of space in it and the sub I have (infinity ref. 8") requires .66 cubic feet. The port was tuned via precision port's web calculator and cross checked with another calculator. Is that the wrong logic?
  10. #10
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,836
    119 Post(s)
    6118 Post(s)
    1" of clearance from the back is fine. Since you have an aeroport, play around with the length until you're happy with its response. You may still need a larger diameter of tube to reduce port noise though. I'm not sure you have enough port area for that sub
  11. #11
    PKP80's Avatar
    Jul 2014
    Los Angeles
    1 Post(s)
    I am going to try a JLW3...requires .35 cubic ft for ported
  1. Center ported box help
    By suicideking187 in forum Enclosure Design & Construction Help
    Last Post: 01-29-2011, 09:12 PM
  2. Custom Center Console Box for Toyota Tacoma
    By psych0ticnemes1 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 11-16-2010, 11:30 PM
  3. custom panel box help ... pic
    By Rsx_03 in forum Subwoofers
    Last Post: 03-10-2006, 10:03 AM
  4. Pics of Custom center console with 10'' JL W7 in it.
    By RSTsilverado in forum Subwoofers
    Last Post: 01-02-2006, 02:39 AM
  5. Custom Ported box help!
    By EdrikLongtail in forum Subwoofers
    Last Post: 06-15-2004, 07:47 PM
