Results 1 to 2 of 2
Reload Thread: alpine swrt12 (shallow) box build
    xxrcm619xx's Avatar
    xxrcm619xx is offline Junior Member
    Jun 2014
    san diego
    Icon14 alpine swrt12 (shallow) box build
    Alright,
    I bought 2 alpine shallow 12s. I have them behind my rear seats of an 06 silverado crewcab (4 door). My sealed Box was bought off of the super sound crew website. When purchased i gave them my sub specs to be built for the set of alpines i have and it is not really built to it. It sounds great still, but i want to go up and beyond. So my question here is has anyone built a ported box for shallows? Is it not recommended? I do want to keep my seats in the rear, so will the little space i have be a huge problem? i do plan on building my self, but before i do i want make sure i dont wwnt to open amd huge can of worms.....
    Here is the specs for my sub
    Subwoofer SeriesType-R (Alpine)
    Subwoofer Size12"
    Peak Power Handling1200*watts
    RMS Power Handling600*watts
    Voice Coil(s)Single
    Impedance (Per Voice Coil)4*ohms
    Frequency Response26 - 200*Hz
    Sensitivity84*dB
    Xmax (millimeters)15*mm
    Subwoofer DesignRound / Circle
    Main Cone ColorBlack
    Woofer CompositionAluminum
    Woofer SurroundSantoprene Rubber
    Subwoofer GrilleOptional (Accessory required and sold separately)
    Alpine KTE-12WG
    Re-Cone Kit AvailableNo
    Recommended Enclosure Specifications
    Recommended Enclosure TypePorted / Vented
    Sealed
    Minimum Sealed Box Volume0.40*cubic feet
    Maximum Sealed Box Volume0.75*cubic feet
    Minimum Ported Box Volume1.0*cubic feet
    Maximum Ported Box Volume1.5*cubic feet
    Top-Mount Depth3-1/2"
    Cutout Diameter10-15/16"
    Shallow Mount InstallationYes
    xxrcm619xx's Avatar
    Jun 2014
    san diego
    Re: alpine swrt12 (shallow) box build
    So a couple days later some research and math formulas later, i decided to try to build a tube port shallow mount box. I got my dimensions setup, over the weekend i plan on buying my MDF, and start my cuts. Post em up later when i get every complete. If it dont turn out the way i like them to sound, i may just buy another Apline SWR-t12 and just add 3 to a sealed box
  1. Rockford P3D4 single sub with Alpine MRV-M500 questions on box build
    By Scalian in forum Enclosure Design & Construction Help
    Last Post: 03-30-2014, 06:58 PM
  2. Box Build 10" Alpine Type r
    By unrated in forum Enclosure Design & Construction Help
    Last Post: 04-09-2010, 01:10 PM
  3. box build for alpine type x....
    By 302yota in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-23-2010, 11:43 PM
  4. box build .75 (each) for two pioneer shallow mount 12"s
    By dcole18 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-21-2008, 09:11 AM
  5. Box building Question?
    By Unregistered in forum Subwoofers
    Last Post: 01-15-2002, 02:53 PM
