Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: quick easy box plans needed
  1. #16
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,788
    232 Post(s)
    7683 Post(s)
    Re: quick easy box plans needed
    Quote Originally Posted by bad @SS chevy View Post
    So what your saying is its a perfect designed box for the alpha v2's?
    could be better(SQ wise) and flatter(buuut space limitations) still, it should work decently. Put up a vid of your subs in action once its done!
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  2. #17
    bad @SS chevy's Avatar
    bad @SS chevy is offline CarAudio.com Veteran
    Jan 2008
    ohio
    2,766
    44 Post(s)
    I'd say I have a pretty "open" space limit lol. 11' grand Cherokee. Better sq as in dropping the frequency range? I honestly don't even know if the parameters are 100% legit but there the only ones I found . there's a alpha box thread from years ago about another guy having issues with his alpha in a box built by a member on here. But ya! For sure going to throw up a video or 2. Like I said if you need a couple bucks in your PayPal hit me up. Greatly appreciate it. And I can move the sub's or 2 6" aero's wherever I want on the fsce right? Like if wanted to put a port on each bottom side of a 12
    2011 Grand Cherokee Limited
    2 12" RD Alpha Weights v2's
    2 12" Atomic ELE's
    2 12" AQ Hdc3's
    1 12" Atomic. APX
    ARC 2500.1
  3. #18
    Jeffdachef's Avatar
    Feb 2013
    15,788
    232 Post(s)
    7683 Post(s)
    yeah your pretty free to do that, just keep them relatively close to eachother.
  4. #19
    Jan 2008
    ohio
    2,766
    44 Post(s)
    Thanks again Jeff. Will send you pics when done going to build it on Sunday... Unless you have any other tweaks or any other plans to make it better speak now or forever hold your peace
    2 12" Atomic ELE's
    2 12" AQ Hdc3's
    1 12" Atomic. APX
    ARC 2500.1
  1. Box Plans Needed Quick!
    By NJack2AF in forum Enclosure Design & Construction Help
    Last Post: 11-28-2010, 11:31 AM
  2. box plans: need to know xmax
    By jchancellortool in forum Enclosure Design & Construction Help
    Last Post: 08-31-2005, 04:58 PM
  3. box plans needed *PICS* cash waiting
    By roy_barber99 in forum Enclosure Design & Construction Help
    Last Post: 08-27-2005, 10:26 AM
  4. box plans needed *PICS* cash waiting
    Last Post: 08-27-2005, 05:04 AM
  5. slot-ported box plans needed for 12 inch kicker comp vr
    By Scarface in forum Enclosure Design & Construction Help
    Last Post: 01-30-2004, 02:00 PM
