Results 1 to 11 of 11
Reload Thread: Help with a ported box design for 2 Kicker CVR 12s
    MrDrRoscoe's Avatar
    MrDrRoscoe is offline Junior Member
    May 2014
    United States
    4 Post(s)
    There's probably been about 50,000 CVR 12 boxes built but I can't find one that will fit in my G6's trunk that actually gives any specs. This is my first box by the way.
    I can have a max of 4.5ft^3 with two of these, each sub uses a recommended 2.25ft^3 which includes sub displacement.
    My max dimensions are 14in height, 36in width, and depth doesn't matter much but probably 24in or less.
    I'll probably do a flush mount just to make it look a little nicer.
    I'm not sure about what to tune the port too or the length, 32Hz sounds like a nice number to me if I can fit it. Every calculator I use seems to give different numbers.
    If anyone can help me design a box I'd be grateful. I've been working on one in SketchUp I'm really just not sure if I'm doing things right.
    Better-Action's Avatar
    Better-Action is offline give me a reach around
    Sep 2012
    SD
    438
    167 Post(s)
    Re: Help with a ported box design for 2 Kicker CVR 12s
    How much power you giving them. I had 2 12 cvrs in a 4cf tuned to 34hz and it did nicely. Build a box and as long as its withing 4-4.5cf 32-38hz tuning and at least 10" of port per cube and you'll do alright.
    Bought from Underfire, Stephens30228, audiobaun.
    MrDrRoscoe's Avatar
    May 2014
    United States
    4 Post(s)
    I'm using this amp, the voice coils are in series and the subs are parallel so the load is 2 ohm
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    33
    8,361
    7 Post(s)
    1337 Post(s)
    Quote Originally Posted by MrDrRoscoe View Post
    There ya go buddy..... Also, that amp is just fine for them..
    Enclosure Specifications:
    Fb = 37,503 Hz
    Vb = 4,5 ft^3
    Subwoofer Mounting = Flush Mounted
    External Height = 14 in
    External Width = 33 in
    External Depth = 25 in
    Port Width = 4 1/2 in
    Cut List:
    * All Dimensions in Inches.
    * Wood Thickness is 3/4 for all Parts.
    External Enclosure Parts:
    Front = 27 3/4 x 12 1/2
    Front Internal = 27 x 12 1/2
    Back = 33 x 12 1/2
    Left & Right Sides:
    Side 1 = 23 1/2 x 12 1/2
    Side 2 = 22 3/4 x 12 1/2
    Top & Bottom = 33 x 25
    L Port Internal Assembly Parts:
    Front to Back = 14 3/4 x 12 1/2
    RIP Maynard "My heart"
    1996 Ford Explorer 4 door XLT
    HU - Eclipse cd-7100 "active"
    Front Stage - 2 Alphard mx60 mids- 2 Alphard mx80 mids - 4 Hertz ST25's
    Front Stage amp - 2 Alphard 200.4
    Subwoofer - Custom
    Subwoofer Amp- Soundigital 8.8k
    Box - 3.5cf tuned @ 33hz
    Wiring/Electrical - 4/0awg weld, JY 79.8Ah lithium, 290&370 hair JS Alternator
  5. Thanks MrDrRoscoe thanked for this post
  6. #5
    MrDrRoscoe's Avatar
    May 2014
    United States
    4 Post(s)
    Quote Originally Posted by disturbed471985 View Post
    Fb = 37,503 Hz
    Vb = 4,5 ft^3
    Is Fb the tuning frequency?
    I had to alter your design a little. The front baffle needs to be 14in high because cutout is 12.625in in diameter, the internal cutout is 11in in diameter so its fine. Also one of the sides was a little short and I had to change the depth of the top and bottom pieces because of the baffle.
    Here are my edits, the weird decimals should be 24.25 and 23.5 when I actually cut them.
    Last edited by MrDrRoscoe; 05-26-2014 at 02:05 PM. Reason: Link to the picture if it doesn't display
  7. #6
    Jun 2009
    Greenwood, La
    33
    8,361
    7 Post(s)
    1337 Post(s)
    Yes to the FB question.. Took a glance at changes an I think all is good
    . Measure twice... ***** to build a box just to have to toss..
    Subwoofer - Custom
  8. #7
    MrDrRoscoe's Avatar
    May 2014
    United States
    4 Post(s)
    I figured it would all be fine since I didn't change any internal dimensions. I already exploded the box and made sure I can get it all on to one sheet of MDF.
    Rounding off the inside port wall and the opening won't affect anything really will it? I may put in a 45 degree in the port also if I can cut it.
    Thanks for the help, you solved my problem and then some!
  9. #8
    Jun 2009
    Greenwood, La
    33
    8,361
    7 Post(s)
    1337 Post(s)
    I have always used 45's in all corners. So I say use them can't hurt. One sheet mdf hmmmmm not sure. I only use birch and if going that route one sheet want make it.. Few years back got tired of replacing shocks every 6-8months. Best audio decession to date.
    Subwoofer - Custom
  10. #9
    MrDrRoscoe's Avatar
    May 2014
    United States
    4 Post(s)
    I might just go ahead and cut 4 45s then for each corner, I might only be able to fit 3 since the there's not a ton of room between subs but that's fine. I put all the pieces beside eachother in SketchUp to see if they'd all fit on a 97x49in sheet of MDF, then I found this optimal cutting calculator which seems to work really well, and it's free.
    I don't know how much this bastard will weigh but hopefully it's not too bad on anything.
  11. #10
    Jun 2009
    Greenwood, La
    33
    8,361
    7 Post(s)
    1337 Post(s)
    Always room to somehow get something on the corners to eliminate those dead spots an get that air flowing smoothly. 1 sheet 3/4mdf plus glue, screws min of 100lbs. Now toss in subs, wiring, amps, and I hope at least a set of batts ur in the 3-400lb range.. That's a lot of weight no matter which way u look at. If my current box was mdf it would weigh a solid 150lbs but by using birch I'm right around 100lbs only draw is price of birch bout double if not more then mdf. Just depends where u live.
    Subwoofer - Custom
  12. #11
    MrDrRoscoe's Avatar
    May 2014
    United States
    4 Post(s)
    After doing some more thinking and modeling, there's basically no way to fit a box that size in to my trunk without building it inside of it. So I might do two 2.25ft^3 boxes and just have to live with that for now.
  1. box sugestions for kicker cvr 12 dual 4 ohm
    By simplemangw in forum Enclosure Design & Construction Help
    Last Post: 01-09-2010, 12:14 PM
  2. Need Help with Orion Ported Box Design
    By LuckyPiston13 in forum Enclosure Design & Construction Help
    Last Post: 03-05-2009, 01:00 PM
  3. need help with this ported box design...
    By aaron7114 in forum Enclosure Design & Construction Help
    Last Post: 02-02-2007, 02:03 AM
  4. need help with my ported box for 2 15L7s
    By talon2nr7588 in forum Enclosure Design & Construction Help
    Last Post: 11-10-2006, 08:32 PM
  5. Need help with a ported box design
    By Jayhawkk in forum Enclosure Design & Construction Help
    Last Post: 10-29-2004, 12:21 AM
