Results 1 to 2 of 2
Reload Thread: Does this setup look good?
    speedyjuarez's Avatar
    speedyjuarez is offline Premium Member speedyjuarez is a Supporting Member of the forum!
    Aug 2013
    Live in Hobbs, NM. From Ft Worth, TX
    519
    257 Post(s)
    Amp 1000.1 zxs
    Rockford fosgate R2SD4-12
    Back seat of 2012 f350
    So I have this spare amp I can use for this build for my work truck (so I don't want to spend tons of money on). I have two RF shallow 12 subs I bought at the flea market.
    I'm not very knowledgeable about air space so if you guys could help me with the best setup for my truck.
    This is the box I think I need that fits behind my rear seat. From the air space that's available I think I should use only one of the 12s that I have. Or could I use both 12 ?
    http://http://caraudiofactory.com/20042013-ford-f250f350-f450-super-duty-carpeted-p-454.html
    PRIME Subwoofers - R2SD4-12 - Rockford Fosgate®
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: Does this setup look good?
    12s wont fit very well 10s would work so much better
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam, will add
    A kingpin camera and a trailer rear cam soon
    Memphis viv component run active
    Kicker cx1200.1
    Kicker cx 300.4
    2 jl 13tw5-3 wired to 1.5ohm at about 1000rms
    ****** box that needs to be replaced soon
  1. does this design look good? or start over??
    By deez283 in forum Enclosure Design & Construction Help
    Last Post: 01-29-2014, 05:28 PM
  2. Does this setup look good? power acoustik
    By cej2995 in forum Subwoofers
    Last Post: 02-26-2010, 01:05 AM
  3. How does this setup look?
    By manslayer in forum General Discussion
    Last Post: 12-19-2008, 01:18 AM
  4. how does this setup look?
    By gmoney69 in forum General Discussion
    Last Post: 07-25-2005, 05:52 PM
  5. Does this setup sound good??
    By Big D8907 in forum Subwoofers
    Last Post: 09-15-2004, 11:54 PM
