Results 1 to 6 of 6
Reload Thread: box shape question
    pnthr30's Avatar
    pnthr30 is offline Junior Member
    Oct 2003
    Milwaukee
    42
    13
    box shape question
    I am planning on building a sealed box for a 10" Alpine Type R (SWR 1021d) sub. I have looked and read a bit on the whole process, but I have seen some differing points regarding shape and wanted to see what you guys think. I am clear on the whole size (volume) issue - in my case, my sub suggests between a .5 and a .8 cubic volume box. I want to make a box with around .66 cubic feet internal volume. Here is where my confusion lies.........Does the shape matter? I have heard that a perfect cube is a bad idea. I would like to stay away from slanted sides (different bottom and top sizes) because I don't want to have to make angular/mitre cuts. Basically, something resembling a rectangle is easier to make. Many people say that as long as it isn't an exact cube you are good to go, but I have seen several places (for example)
    http://www.loudspeakers101.com/BoxCalc.htm
    http://www.kbapps.com/construction.html
    that talk about the "golden ratio". Is this ratio of side length that important? Will there be a noticable difference in sound? I calculated my side length with this ratio and I don't really like the shape. Also, it appears that the pre-made boxes (Q logic for example) do not follow this ratio. Anyone have any insights?
    Also, what gauge speaker wire do you suggest? I am pushing this sub with a RF 250a2.
    Thanks!
    By the way, the shape I want to use (outside edge to outside edge) is 12 x 12 x 12 (with 3/4" MDF) (internally 10.5 x 10.5 x 10.5) which gives me an internal volume of .6699. What do you guys think of that?
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: box shape question
    The shape is not very important. You will not hear a difference as long as the enclosure is solidly built. The "golden ratio" is more important when you are dealing with woofers that are playing a larger spectrum of frequencies rather than subs. In the higher frequencies, you have to start worrying about standing waves in the enclosure. Not so with the low freqs fed to a sub.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    As far as the shape of the enclosure goes. It could be a perfect cube that small. It isn't big enough for a standing wave to form in. As for wire guage you might as well use 12ga it's pretty cheap.
    5 % equipment
    90 % install
    5% beer
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    [email protected] I'm old and slow .
    5 % equipment
    90 % install
    5% beer
    Dec 2001
    Violates Miranda
    3,238
    Quote Originally Posted by helotaxi
    so if i have my lpf at 80 there is no chance of a standing wave even in a perfect cube box? and also how much of a difference would the sound be between these 2 boxes... not going by cuft but by how the subs are facing and the shape.
    http://bigdogaudio.com/proddetail.asp?prod=122SLREV
    or..http://bigdogaudio.com/proddetail.asp?prod=BIG122SQR
    just curious between the hatchback style and the second box which is basically a cube shape for each sub.
    pnthr30's Avatar
    Oct 2003
    Milwaukee
    42
    13
    Thanks for the input (and knowledge) guys, I appreciate it!
  1. box question
    By raga55 in forum Enclosure Design & Construction Help
    Last Post: 04-02-2004, 03:59 AM
  2. Re8 box size Question
    By Dupuis in forum Subwoofers
    Last Post: 01-26-2004, 04:28 PM
  3. ported box question
    By abcdefg in forum General Discussion
    Last Post: 11-22-2003, 03:19 PM
  4. help me with a box for JBL GTI 10s
    By slug420 in forum Enclosure Design & Construction Help
    Last Post: 10-28-2003, 11:51 AM
