Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 35
Reload Thread: Poorly designed 4th order
  1. #16
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: Poorly designed 4th order
    And if you are wondering why I had so much rise, it was a 5:1 4th with 113in^2 of port area, it was ridiculously efficient.
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  2. #17
    4bannger's Avatar
    4bannger is offline Senior VIP Member
    Nov 2012
    FLA
    292
    90 Post(s)
    Quote Originally Posted by RangerDangerV2 View Post
    Didn't know this would become an argument lmao.
  3. #18
    Jes 42's Avatar
    Jes 42 is offline DeezNtzz
    Aug 2012
    Ohio
    2,383
    4 Post(s)
    709 Post(s)
    Quote Originally Posted by 4bannger View Post
    It's ca.com
    Pioneer 880PRS
    4 PRV 6.5's 4 Bazooka Euphonic os tweets
    Kicker KX850.4
    2 Incriminator Death Penalty 18's
    American Bass VFL450.1
    300 amp Ohio Gen alt
    4 Deka Intimidator's in back.C&D 77ah up front.
    Lotta 1/0 welding wire
  4. #19
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    So your saying that if i make 4 cubes sealed and since i have to divide the chamber each sub would get 2 cubes, and then a 4 cube ported section?
    yes
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  5. #20
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,186
    15
    38 Post(s)
    4189 Post(s)
    Just setting the record straight that you were essentially running 4K
  6. Likes jrdnhsnbrg liked this post
  7. #21
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    Quote Originally Posted by Beatin' View Post
    yes
    so the 1:1 ratio isnt the problem it was the amount of space i was using? would i be better off doing a ported box as far as it being louder?
  8. #22
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    yes overall the box is way too large I would have went with something like 1:1.5 basically 4 sealed and 6 cubes ported tuned around 60hz should do nice but I am not a 4th order king just done a ton of reading and from my understanding the larger the ratio the larger and faster the roll off is basically becoming a 1 note wonder now a ported box will get the job done but if ya want something different a 4th order can be real nice and impressive. you also have to be real careful on the port area it cant be real large.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  9. #23
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    Quote Originally Posted by dbeez View Post
    what kind of port area should i shoot for? im still undecided if i wanna go with a 4th or ported for my next box build
  10. #24
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    From my understanding is 1/2 your cone area
    2002 suburban
  11. #25
    Jul 2007
    Futurama
    1,481
    44 Post(s)
    You wont know until you build it. I would build a sealed box with a qtc of .707, find the resonance, do a 1:3 ratio ratio and use 1/2 cone area amount of port area tuned to the sealed resonance and just see how it sounds. To peaky, shrink the front, doesnt play low enough, tune the port lower, isnt loud enough, up the port area, subs unload to easy, make a loading wall. Once boxes are in the car its all testing, why do you think all the big 4th order builds have multiple test vids with no port and differnt ports? Its all about testing. Just make it to where the front can be totally changed and just goof with it.
    Thats what it is all about lol
    Quote Originally Posted by bunkerking09 View Post
    i have a little weiner
  12. #26
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,075
    20 Post(s)
    1347 Post(s)
    1. Get your sealed Fc around 45-55 (depending on goals)
    2. Tune to or around Fc
    3. 2:1 or higher ratio for output, 1.5ish or less if you don't care if you lose a dB or two
    40Hz is just too low for a 4th order, plus your ratio was too small. If you don't know what you're doing, a ported box is a lot easier to get right
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  13. #27
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    Quote Originally Posted by SounDrive View Post
    Well i was thinking about just going with a ported box. I've mad a few designs can you tell me if any of these would be a good design for a ported box?
    -I'm not sure how good down-fire boxes work so this is just a concept for a box. is there any special things that a down-fire box needs different than a ported?
    Poorly designed 4th order-downfire5.jpgPoorly designed 4th order-downfire4.jpgPoorly designed 4th order-downfire.jpg
    -This is a ported box i was thinking about. The angled piece on the top is just a concept of an amp rack with plexi glass and the holes in the back are for cooling fans.
    Poorly designed 4th order-ported1.jpgPoorly designed 4th order-ported2.jpgPoorly designed 4th order-ported3.jpg
    Attached Thumbnails Attached Thumbnails Poorly designed 4th order-downfire3.png   Poorly designed 4th order-downfire2.jpg
  14. #28
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by hispls View Post
    yeah? so are you trying to say that my woofers were actually getting 4kw? No, they were not. I would think that you of all people would understand this.
    1999 Tahoe
    2 sa12s
    4th order
  15. #29
    hispls's Avatar
    Sep 2009
    10,186
    15
    38 Post(s)
    4189 Post(s)
    I understand, but your claim is a bit misleading and you know it.
  16. #30
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    more help less argue please
  1. need 2 boxed designed 4th order and aero port
    By jonny101abc in forum Enclosure Design & Construction Help
    Last Post: 07-03-2009, 01:39 PM
  2. 4th order bandpass, wheel well design :) (design inside)
    By TWOJZ in forum Enclosure Design & Construction Help
    Last Post: 01-09-2008, 02:26 PM
  3. 4th Order Bandpass Design
    By rpfuror in forum Enclosure Design & Construction Help
    Last Post: 01-23-2007, 06:21 PM
  4. 4th order box for 4 eD 9Kv.2's, designed by 80INCHES **PICS and VIDS**
    By IonSQL in forum Enclosure Design & Construction Help
    Last Post: 11-13-2006, 12:38 AM
  5. 4th Order box Designed and done by......
    By vetkilr in forum General Discussion
    Last Post: 09-19-2006, 07:42 AM
