Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 77
Reload Thread: Sub placement, does it matter?
  1. #61
    MellowHype's Avatar
    MellowHype is offline Senior VIP Member
    Mar 2012
    Uk, London
    198
    64 Post(s)
    Re: Sub placement, does it matter?
    Quote Originally Posted by hispls View Post
    Where are you getting these voltage numbers? How have you verified the impedance of your sub at all these frequencies that you're testing?
    Just going by the formula for working and setting gains by using a multimeter in a tutorial on here (scroll down to subwoofer part). Then using the subsonic filter setting part, thats where i got those frequency's above
    Gain Setting Tutorial
    Subs are wired to 1 ohm and amp at 1000watts. square root of 1000 = 31.62v
    I dont know what you mean by verified impedance at different frequency.
  2. #62
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,953
    15
    36 Post(s)
    4040 Post(s)
    Quote Originally Posted by MellowHype View Post
    Your amp will virtually never see 1 ohm while playing those woofers and playing around with a dmm beyond testing continuity of your connections is worthless.
  3. #63
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    So how would you recommend setting subsonic filter? or gains? I also dont understand why the amp wouldnt see 1 ohm other than resistance in the wires etc
  4. #64
    phemps's Avatar
    phemps is offline CarAudio.com Veteran
    May 2009
    PA
    2,023
    284 Post(s)
    Becuase its not simple DC resistance and the woofers have an impedance curve. I set my subsonic at 1/3 octave or so below tuning
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
  5. #65
    hispls's Avatar
    Sep 2009
    9,953
    15
    36 Post(s)
    4040 Post(s)
    What he said ^^^
  6. #66
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    could you tell me what a 1/3 octave of 34hz would be please?
    Just got my new test leads and got the same figures, now i think its to do with the test track i used. I just dragged the test track into audacity and showed clipping and the whole thing was red indicating clipping all over.
    All i did was create tone, and set amplitude to 1. Is this not correct?
    Only thing i can think of is that maybe i made a -3db track before, ill give that a go in while
  7. #67
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    Ive now spoke to a car audio specialist who is kind of local, and he owns a DD-1 and will set my amp for $25.
    Is that the best way for me to go about this to get the most out of my amp and subs?
  8. #68
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    i used the -3db 60hz tone and im sure its still not right. Its only a little louder than when i had a single R on 700 watts.
    Think im gonna have to take it to the person with the DD-1. Whats your guys opinions on the DD-1?
  9. #69
    phemps's Avatar
    May 2009
    PA
    2,023
    284 Post(s)
    Approximately 28 HZ is 1/3 octave down. An Octave is one half, or double a frequency so and octave below 34 is 17 hz/3 is 5.66 hz. 34-6 gives you your subsonic setting. As far as the DD1 goes... I have one and they do the job
  10. Thanks MellowHype thanked for this post
  11. #70
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    Waiting on a reply from the person with the DD-1
    In the meantime i went and put a fresh battery in my DMM and i set the volts to 32 which is like square root of 1030 watts even though my amp is only rated at tad over 1000, and it went from being like one R to quite alot louder but it made my lights dim like crazy. Also standing from the outside of the car its definitely not loud.
    really hoping that the DD-1 gets alot more out of these subs, im happy to add another battery, but its just annoying if i had known the gain going from one 12 @ 700 to 2 12's @ 500 each, would have only been as much as i have seen so far i wouldnt have bothered.
  12. #71
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    Just thought id upload a couple pics of the finish
    Im now looking into a car with a boot that should get 5ft^3 in it so those Rs will perform better and then next on the list will be a 2k rms amp
  13. #72
    hispls's Avatar
    Sep 2009
    9,953
    15
    36 Post(s)
    4040 Post(s)
    Have you considered just turning up the gain until you can hear distortion while playing music? How about just fiddling with your crossover settings until you're not over-driving the woofers mechanically? I can't believe you're actually considering paying someone 25$ to do something you could do in a couple minutes.
  14. #73
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    Well ive set the high pass to 80 and the subsonic to around 30.
    I guess i could give setting the gains by ear a go, its just i dont wanna push my amp too much and kill it. I definitely think the amp has got more than what im pushing it to.
    I was wondering aswell, ive found some KnuKonceptz KLM 4 gauge thats very very cheap, and i was thinking of doing the big 3 with that, as it says its good up to 250 amps. The thing is though its CCA aswell and 4 gauge so i dont know if id be wasting my time.
  15. #74
    hispls's Avatar
    Sep 2009
    9,953
    15
    36 Post(s)
    4040 Post(s)
    Assuming you fused your amp correctly and it has functioning protection circuits it's unlikely you'll break it by over-driving your subs a little
  16. #75
    MellowHype's Avatar
    Mar 2012
    Uk, London
    198
    64 Post(s)
    i think my amp has 3 x 35 amp fuses in it, the 4 awg wire used is fused with 150 amp. Is there a chance my 100 amp alternator or low end battery could be anything to do with the lack in power? my lights dim like crazy
  1. Inverted sub box height....does it matter how tall?
    By Jroo in forum Enclosure Design & Construction Help
    Last Post: 01-12-2012, 02:28 PM
  2. does it matter where you mount the sub for ported boxes
    By nauc in forum General Discussion
    Last Post: 08-17-2011, 02:33 AM
  3. Port placement: does it matter?
    By 1ndatrunk in forum Enclosure Design & Construction Help
    Last Post: 12-27-2009, 01:42 AM
  4. Does it matter where I mount the sub on a ported box?
    By cheeto in forum Enclosure Design & Construction Help
    Last Post: 01-30-2008, 03:48 PM
  5. does it matter which way subs face in a trunk car?
    By talon2nr7588 in forum General Discussion
    Last Post: 10-31-2006, 08:46 AM
Tags for this Thread
