Results 1 to 4 of 4
Reload Thread: need help.
    tat2's Avatar
    tat2 is offline Senior VIP Member
    Jan 2004
    mass
    33
    448
    need help.
    i need some help, some one tossed me a box plan but it's to deep.
    Here is the design that I did for my buddy. It is tuned to 40 Hz
    This is for a dual chamber box. External measurements are 14" tall x
    31.25" wide x 30" deep.
    (2) 30" x 31.25" <--- top and bottom
    (2) 13.25" x 12.5" <--- Fronts
    (3) 29.25" x 12.5" <--- Sides and middle
    (2) 12.5" x 11" <--- Inside Port wall
    (1) 12.5" x 29.75" <--- Back
    i need it to be 25" deep. how would i go about resizing it. i can go tall and wider, i just don't know how to do it and have it the same all aroundsize and tune.
    and should i keep it tune like that, it'll be in a jeep off a pg t1200.1 i like lots of spl and like to hit pretty low. if i need to change the tuning how do i do that also.
    thanks.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Re: need help.
    35" wide x 25" deep x 15" high will get you the same numbers...
    top/bottom: 25" x 35" (2)
    sides: 25" x 13.5" (2)
    middle: 23.5" x 13.5" (1)
    front: 13.5" x 28" (1)
    back: 13.5" x 33.5" (1)
    port: 13.5" x 14" (2)
    This will give you 2" x 13.5" ports and tune it to 38Hz. The ports are on the outside edges and the middle is not seen, hence the single front baffle.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    tat2's Avatar
    Jan 2004
    mass
    33
    448
    Re: need help.
    thanks a lot bro thats mad cool.
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Re: need help.
    NP. Let me now if you need anything else.
    2006 Jeep Liberty
    *Vb = vol. in cu"
