Results 1 to 12 of 12
Reload Thread: Building my first ported
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    I ran my dumax TS parameters from ED thru winisd, and came up with a 1.724 cu/ft box, tuned for 26.8hz, with a 2 inch diameter port, thats 5.19 inches long.
    which will fit into my limits for construction, assuming pvc pipe is a valid port material.
    does this sound right? Should I tune higher or lower?
    From the Spec sheet wth my 12a:
    fs: 27.34 hz
    qe: .45
    qm: 4.71
    qts: .41
    vas: 46.27 ltr
    sd: 0.0465 m^2
    re: 3.61 ohm
    mmd: 216.80 g
    cms: 0.0002 m/n .152339 mm/n
    rms: 8.12 ohmm
    sd: 0.0465 m^2 effective radius
    bl: 17.49 n/a
    re: 3.61 ohm
    xmag: 29.5 mm
    Xsus 26.00
    Xmax 25.4
    mag center -2.2mm
    sus center 2.6mm
    Also its going in my blazer, firing toward the tailgate if it wont sound better firing up?
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    Re: Building my first ported
    You will have serious issues with port noise. You need a much larger port to keep the velocity of the air moving through it down. It will require a longer port, but the 2" port will sound terrible.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    2.11 cuft after dispacement. Tuned to 26.8 hz. 4" port, 19.5" long. Nice and flat. Face the sub up with the port firing back to the tailgate.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
    Fitz's Avatar
    Fitz is offline Audio is my life.
    May 2004
    Omaha, NE
    258
    i've seen it on several seperate occasions... does it matter what way the port faces/which way the port entrance is in the box.. and how does it affect SQ/SPL?
    2002 Black Chevrolet S-10 ZR-2 Truck (Extended Cab)
    Clarion DXZ945mp
    Diamond S600s, Diamond 341i
    Stinger PVR 2 1000
    Diamond d61500.1, d6300.4
    one DB drive 12d4 in 2.3 ft tuned to 29hz
    Coming sometime: big 3 upgrade, Iraggi 220/175 alt, rl-p
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    31
    368
    Quote Originally Posted by dbornotdb
    can the 4 inch diameter pipe have a bend in it? since I cant fit that much back..or should I just use a slot port and get it to equal the same port volume?
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by Fitz
    What you don't want is for the port to exit on the opposite side of the subs mounting surface. The backwave would just go straight through and out the port. Not really allowing for a wave to develope. I might not have explained it exact, put you get the idea.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by TPABlazer
    The PVC can definatly have a bend in it. Just remember to subtract for the length of the bend when added.
    And if you choose to slot port it, the opening of the slot has to equal the opening of the round in square inches. Once you have that, the length of the port is the same. The length is what tunes the box.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    I also wanted to add this so it might help you understand how to change the ports.
    Round To Square Port Conversions
    Pie x R squared
    For example::Say you have a 6" port that is 13" long, take half of the port size (Radius), in this case 3". Now multiply 3x3, (R squared). This is 9. Now do 9xPie, which is 9x3.14. Now you just got the square inch of your port. In this case 28.26.
    Now you can design a square, rectangle, triangle or a port that is the sub logo. As long as you match the square inch.
    For example::28.26 could be made into a 3"x9 3/8" opening, 13" long.
    The lenghth of the port will stay the same. It determins the tuning frequency and is not effected by the conversion.
  9. #9
    helotaxi's Avatar
    Dec 2003
    37
    8,945
    This depends entirely on how everything is facing. You don't need "a wave to develop" we are not building a TL enclosure based on 1/4 wave theory, we are building a bass reflex enclosure based on a Helmholtz resonator. Basically the way the standard ported enclosure works is it vents the pressure created by the inward stroke of the sub and the resistance created by the length and area of the port slow the pulse so that it is in phase with the pressure wave created by the outward stroke of the sub. The pressure coming from the port will be perfectly in phase with the direct pressure from the sub at the tuning frequency. As you move away from tuning the phasing becomes less and less perfect and the reinforcement becomes less and less. Any time the port opening is not on the same face and on the same plane as the sub itself, the phasing will be other than optimal. You can negate some of this by corner loading the port or the sub and allowing the pressure coming from one or the other to reflect off a trunk wall. It will not be perfectly in phase but it will be better than nothing.
  10. #10
    helotaxi's Avatar
    Dec 2003
    37
    8,945
    [COLOR=Blue]The PVC can definatly have a bend in it. Just remember to subtract for the length of the bend when added.
    You don't use the whole length of the bend. The bend is equivelent to a length of the pipe as long as the elbow section measured down the center.
  11. #11
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by helotaxi
    Correct. You do not measure the "bell" end of the bends. You measure the actual usable pipe there. You measure from end to end using the center as a guide to get correct measurments.
  12. #12
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    31
    368
    eh?i dont get this measuering across the bell but not the elbow and then carry the niner...
  1. Need Help Building a SIK ported box!
    By LoudCrownVic in forum Subwoofers
    Last Post: 07-27-2004, 02:48 PM
  2. Building a ported box for 2 Pg ti 10's
    By Bryce M in forum Enclosure Design & Construction Help
    Last Post: 05-25-2004, 08:58 PM
  3. Final checklist before building impressive trunk setup
    By danfortner in forum Enclosure Design & Construction Help
    Last Post: 12-21-2003, 11:16 PM
  4. building a ported box (2cu ft) for 10 inch
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-08-2003, 01:52 PM
  5. any sites on building a ported enclosure
    By DbRufus1234 in forum Enclosure Design & Construction Help
    Last Post: 09-23-2003, 11:03 PM
