Results 1 to 3 of 3
Reload Thread: help with speaker box
    hunter57255's Avatar
    hunter57255 is offline Member
    May 2004
    new effington ,SD
    31
    i need help with a speaker box i built one a couple of days ago and i saw on ebay some people put foam in there i was wondering what i should put in mine and what would the foam do to the speaker box
    if you have any answer email me at mattpalm@yahoo.com or post a message
    Thanks
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    Re: help with speaker box
    It's not foam, it is poly-fill. You can pick it up in the fabric/craft section of Wal-Mart. You add it loosely to the inside of the box to slow down the backwave and make the sub act like it is in a bigger enclosure.
    But add to much and it will actually take space away so use it sparingly.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Also, becareful adding too much to your box if it is ported because it could throw off your tuning.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  1. bigger box = lower bass???
    By infinity1412 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2004, 01:01 PM
  2. New box?
    By AFaceInTheCrowd in forum Enclosure Design & Construction Help
    Last Post: 03-25-2004, 12:20 AM
  3. depth of speaker > depth of box
    By wesleywahl in forum Enclosure Design & Construction Help
    Last Post: 02-14-2004, 11:38 AM
  4. SQ box building hints/tips/primer?
    By Zylo in forum Enclosure Design & Construction Help
    Last Post: 02-03-2004, 11:23 AM
  5. Need box dimensions for 15'' HC - Building tomorrow
    By BiaBia in forum Enclosure Design & Construction Help
    Last Post: 11-25-2003, 09:46 AM
