Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Reload Thread: 4th order design 2 alpine type r 15's
  1. #31
    4bannger's Avatar
    4bannger is offline Senior VIP Member
    Nov 2012
    FLA
    292
    90 Post(s)
    Re: 4th order design 2 alpine type r 15's
    Quote Originally Posted by Tenacious. View Post
    That one looks better. Would an external port be possible in your vehicle? It would be easier to adjust tuning and port area on if you desired.
    Yes it would be I have a SUV and I took out my third row so I have Max room of like 47x50 I'm gonna revise the design one more time and put the adjustable port external and onto of the box to be more esthetically pleasing (well to my taste) and your right. It would be easier because changing the port length and volume would change the overall volume and effect my ratio and tuning if I'm right?
  2. #32
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Quote Originally Posted by 4bannger View Post
    Yes that's correct. Having an external port makes sure that you won't be changing the volume.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  3. #33
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    thanks learning a lot from you and all the other helpful people on this forum. I knew i could find someone knowledgable enough to help me with this. this is the final design here the tuning is the same, port size same except for length
    Attached Thumbnails Attached Thumbnails 4th order design 2 alpine type r 15's-4thorderbox2.0.jpg
  4. #34
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Where will the port be firing? Towards the rear I'm assuming?
  5. #35
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    firing up towards the headliner.
  6. #36
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    It may be louder with a surface to load off of. Port back (or on the side depending on the vehicle) usually works well.
  7. #37
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    yeah I would NOT do port up in an SUV, especially in a 4th order. Many times upfiring causes nulls in upper bass response and that's really going to limit how high you sub will play if you have a sharp null like that, usually it's around 60hz. The low end tends to be better when you fire directly off the rear too, so you'd be screwing yourself on both fronts. My SUV is sub up port back right now, but since my subs can play upper bass no problem, I'll be doing sub back port back here very soon.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  8. #38
    4bannger's Avatar
    Nov 2012
    FLA
    292
    90 Post(s)
    well weather i was to fire it at the hatch door or at the roof i would have the same about of space between the port and door and roof
    Quote Originally Posted by T3mpest View Post
    Yeah ill take some quick measurment and see whats up. Thanks for the suggestion. I knew that to be true subs but not ports.
  1. Alpine type r 15"
    By RavE in forum Subwoofers
    Last Post: 09-17-2002, 01:39 AM
  2. alpine type-r 15" and amp question
    By spike_spiegel in forum General Discussion
    Last Post: 07-25-2002, 10:42 PM
  3. 3 alpine type r 15s, jbl 1200.1, 2 jbl 600.1????
    By kixazz2529 in forum Subwoofers
    Last Post: 07-09-2002, 08:39 PM
  4. ALPINE TYPE R 15" 2ohm DVC
    By MR_LOWRIDER in forum Subwoofers
    Last Post: 04-23-2002, 06:18 PM
  5. Alpine Type R 15" OR Hx2 15"
    By Fosgatepower in forum Subwoofers
    Last Post: 03-28-2002, 10:03 PM
