Results 1 to 3 of 3
Reload Thread: 24" SHD enclosure help
    72Impala's Avatar
    72Impala is offline CarAudio.com Elite
    Mar 2005
    Clarksville, TN
    29
    1,097
    8 Post(s)
    346 Post(s)
    Ok so I'm thinking of buying a 24" top assembly from Tantric, for my SHD motor. I was thinking of doing a 4th order blow through in my 2008 ext cab silverado.
    Currently I have one of the rear seats out, and have my single 15" ss xxx in 4.5 net, tuned to 29hz. I have a nsb 110 under that (under false floor). My gp3k is behind the two remaining rear seats, and my ppi900.4 is under the passenger seat.
    I want to do the 24" SHD, a rockford T30001-bd, and rockford t800-4bd.
    The 800-4 won't fit under the passenger seat, the t30001 can't go behind the seats if I'm doing a blow through (which I will have to do for a 24" sub if I want to keep any rear seats).
    I'm looking for ideas of where to put the amps, and some help with enclosure design. I HAVE TO KEEP AT LEAST 2 REAR SEATS!!
    Has anyone done a blow through with a single 24" sub on here before?
    Any ideas help, thanks in advance.
    Btw, I have two more Duracell Agm batts under the hood as well as the nsb110.
    2003 6.8L V10 Excursion Limited
    2015 MECA STREET 5 WORLD CHAMP
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Re: 24" SHD enclosure help
    Definitely not a fan of what you are trying to do. In the end the t3000 has to go somewhere and since to only spot left is the roof of the cab or the bed u have no good option.
    really the whole 24inch craze was started by allen just to say its bigger than ia and dd subs but really doesnt lend any advantage in typical installs. But in infinite baffle it can be a godsend if you have the room.
    my recommendation would be like 15cubs ported for the 1 24. I can fit alot of subs in that amout of space. 4 15s for instance
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
    72Impala's Avatar
    Mar 2005
    Clarksville, TN
    29
    1,097
    8 Post(s)
    346 Post(s)
    Quote Originally Posted by winkychevelle View Post
    Yea I am having trouble figuring this out, pretty much want to do this because I've run every size sub except 24", and I like having something different than most around. I'm hoping the t30001 can maybe fit under the rear seats but who knows.
  1. custom enclosure help
    By djjdnap in forum General Discussion
    Last Post: 05-01-2002, 09:48 PM
  2. Sub enclosure help
    By KARLEON in forum General Discussion
    Last Post: 03-24-2002, 09:21 PM
  3. 6x9 enclosure help
    By eschoon20 in forum Subwoofers
    Last Post: 03-10-2002, 10:55 PM
  4. Enclosure help S.O.S please!
    By Unregistered in forum Subwoofers
    Last Post: 02-09-2002, 07:06 AM
  5. Sub Enclosure HELP!!!!!!!!
    By one_bad_55 in forum General Discussion
    Last Post: 01-20-2002, 07:47 AM
