Results 1 to 3 of 3
Reload Thread: Building a ported box for 2 Pg ti 10's
    Bryce M's Avatar
    Bryce M is offline Member
    May 2004
    langley
    35
    I wanted to build a fiberglass box but you cant build a ported fiberglass box because of the fact the volume isnt always what you expect it to be right? or am I wrong? in my trunk I have up to 40 wide between the two wheel wells and the sky is the limit in height or depth. I havent decsided how many hertz it should fire at I want it to sound good at a lower level and have a high Spl when I want it.
    How do I ake a port plug? what should I shoot for how big of a port would I have to build to get 44 Hz and then use a port plug to get it down to 32 HZ for DD. sound like a good idea or am I way off track>?
    Bryce M's Avatar
    May 2004
    langley
    35
    Re: Building a ported box for 2 Pg ti 10's
    According to PG I need
    Vb .75 Vd 3" Vl 13.5" Vented per sub before sub displacement for SPL
    Mounting Depth is 5 3/4 Speaker displacement is 0.1
    Thats a small box or at least it seems like it that means All i need is 1.52 cubic feet
    Maybe I should Go for the 15's instead?
    Bryce M's Avatar
    May 2004
    langley
    35
    I think I am going to Stick with Mdf just for simplicity on Pg's page they say to use 1 inch mdf should i be using 1 inch mdf? because 3/4 is pretty **** strong
    How big of a port do i want do i just multiply the size by the number of subs?
  1. ported box help
    By riddla in forum Enclosure Design & Construction Help
    Last Post: 05-09-2004, 12:24 PM
  2. Replies: 5
    Last Post: 12-05-2003, 11:51 AM
  3. Wanna build ported box for 4 Type E's, Need help!
    By Afboy143 in forum Enclosure Design & Construction Help
    Last Post: 12-01-2003, 10:17 AM
  4. Need help on ported box for a small trunk
    By BulldogSr04 in forum Enclosure Design & Construction Help
    Last Post: 10-09-2003, 04:54 PM
  5. building a ported box (2cu ft) for 10 inch
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-08-2003, 01:52 PM
