Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: 4th order bandpass enclosure help
  1. #16
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    Re: 4th order bandpass enclosure help
    Quote Originally Posted by jeffdachef View Post
    even if the trunk is really big, 2 15s 4th order in a trunk is kind of stretching it, unless you build it inside the trunk and take out the spare tire compartment. I wish you the best of luck though.
    the 2:1 is a solid choice and gives you a pretty good handling and bandwidth. the 2.5 : 1 has the potential to be a lot more peaky depending on the tuning.
    I too have a design for 2 bandpassed 15's in a trunk. It will not be a blow through however. Each sub will also get its own box due to a small trunk opening.
    My setup will be 1.52cuf ported and 1.7cuf sealed after all displacements. 65hz tuning. It was modeled with my cars resonance frequency and cabin gain in mind. Can't wait to build it! wooooo hoooooo!
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  2. #17
    Buck's Avatar
    Buck is offline designing boxes Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,823
    33 Post(s)
    1195 Post(s)
    You'd probably want to do a ported box. What car is it?
    [email protected]
    I help with full system support, if you need advice
    I just like making people happy
  3. #18
    Audiopipe's Avatar
    Audiopipe is offline Junior Member
    Oct 2013
    Spring hill fl
    3 Post(s)
    95 Mercedes c220
  4. #19
    Audiopipe's Avatar
    Oct 2013
    Spring hill fl
    3 Post(s)
    I've heard a lot of negative reactions across the board with a forth order in a trunk so I think I'm just gonna try to do a ported box with the port going threw my blow threw in my rear deck
  5. #20
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,116
    244 Post(s)
    7873 Post(s)
    Quote Originally Posted by Audiopipe View Post
    good call.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  6. #21
    Audiopipe's Avatar
    Oct 2013
    Spring hill fl
    3 Post(s)
    Should I build to spec or half a cube more I heard a little more is better then spec .... Any opinions ?
  7. #22
    Beatin''s Avatar
    Nov 2012
    MI
    998
    574 Post(s)
    good call.
    How the hell is that a good call.
    Ported setups need the cone to take care of upper bass frequencies and the port deals with the lower frequencies. A blow through ported will give you lows, and no highs, especially in a Benz.
    I had the same issue designing a ported setup in a trunk with 2 15's. I found that I couldn't load the cones and the ports off of the same wall, so I chose to go with a 4th order instead.
    voltage be dippin'
  8. #23
    UsAmpsFreak's Avatar
    UsAmpsFreak is offline Senior VIP Member
    Oct 2013
    North Dakota
    308
    124 Post(s)
    It's actually going in a trunk of a Benz but has a custom fiberglass rear deck with a big blow threw
    Unless you are planning to take out the back seat so the port blows through a huge opening like that i wouldn't do it, all you're going to do regardless of how big the cutout on the rear deck is it's just going to greatly bottleneck the output from the box. 70-80% of the energy created will never leave the trunk.
  9. #24
    Jeffdachef's Avatar
    Feb 2013
    16,116
    244 Post(s)
    7873 Post(s)
    Quote Originally Posted by Beatin' View Post
    its purely space wise, and the highs part, you can always tune a lil bit higher have the subs up and port to the rear to remedy the highs. its going to be difficult fitting the necessary space in his trunk, those subs might suffocate in a 4th order which can severely impact the sound.
  10. #25
    Audiopipe's Avatar
    Oct 2013
    Spring hill fl
    3 Post(s)
    The cut blow threw is only like 14x10 . I just would like how everyone else would is more output I have them in a prefab sealed now that's only 4.4 cube and seals rec is 3 per but I would love to hit more low then high but I want my cake and eat it to
  11. #26
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    just read my 4th order thread. loads of useful info
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  1. 4 12 inch hifonics hfis 4th order bandpass help.
    By marcotheclepto in forum Enclosure Design & Construction Help
    Last Post: 12-13-2009, 12:53 PM
  2. 4th order bandpass design help
    By herbykw in forum Enclosure Design & Construction Help
    Last Post: 11-28-2009, 11:36 PM
  3. 4th Order Bandpass Help
    By GearGuy2001 in forum Enclosure Design & Construction Help
    Last Post: 05-14-2009, 10:36 AM
  4. Need help with a 4th order bandpass box
    By Brian Owens in forum Subwoofers
    Last Post: 04-17-2007, 10:39 AM
  5. Replies: 7
    Last Post: 02-25-2006, 08:06 PM
Tags for this Thread
