Results 1 to 4 of 4
Reload Thread: port size vs length for 2 tens in a decently big box.
    Synastr's Avatar
    Synastr is offline Member
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    Ok, so my box cft after subs is right around 3cft. i can build it less if need be. The subs are re pro sr series. ill list the specs. The question im after is, im porting it to run about 31-32 hz. i cannot decide on what port size to use or how many. im thinking either two 3" or one 4" possibly two 4". Ive never designed a ported box so im not 100% on how to tune the ports to it. they recomend 1cft per sub at 35hz but i want it to still go low but have a lot of punch to the bass.
    a member on here recomended 2.5 cft and i can build from 1cft for both all the way up to 3cft.
    Electrical Q Value -Qes 0.39
    Mechanical Q Value -Qms 5.5
    Total Speaker Q Value -Qts 0.36
    Free Air Resonance -Fs 25.3 Hz
    Equivalent Compliance -Vas 31 liters
    One-Way, Linear Excursion -Xmax 18 mm
    Efficiency -SPL 1W/1m 85.3 dB SPL
    Effective Piston Area -Sd 310 cm^2
    DC Resistance -Re 1.8 ohm
    Nominal Impedance -Znom Dual 2 or 4 ohm
    Thermal Power Handling -Pe(RMS) 320W
    Force Factor -Bl 14.35
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    Re: port size vs length for 2 tens in a decently big box.
    ok ive decided to build the box at 2.2 cft after sub displacment, to allow for room for my amp rack. now ive went to port caculaters and still need to know whether to use 1 or 2 ports. it says 1 3" port should only be 7.5 inches long and 2 should be about 16. does that mean two 7.5 port? or two 16 inch ports?
    slam's Avatar
    slam is offline CarAudio.com Veteran
    Oct 2005
    fort worth, tx
    45
    5,470
    52 Post(s)
    I have a box at 2.14^3 tuned at 26hz and is 26.xx long. Believe its 2.5 x 8 x 26.xx
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    im doing a round port though. and im tuning a little bit higher than that.
  1. Just need a port size and length for this box thanks
    By hybrdaccent in forum Enclosure Design & Construction Help
    Last Post: 10-11-2012, 10:56 PM
  2. Recommended Port diameter and length for 10in Type-R
    By Excalibur0428 in forum Enclosure Design & Construction Help
    Last Post: 11-26-2007, 08:27 PM
  3. port size(sq inches) for rl-p 15.
    By neonrt in forum Enclosure Design & Construction Help
    Last Post: 06-15-2006, 04:16 AM
  4. Anyone know what the port size would be for this design of box?
    By supraman1379 in forum Enclosure Design & Construction Help
    Last Post: 08-15-2005, 08:04 PM
  5. RE SE vs SX for SQ in sealed
    By edvurd in forum Subwoofers
    Last Post: 03-24-2005, 05:20 AM
