Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: Slot ported enclosure for 12" Tantric HDD
    Iloveweed1864's Avatar
    Iloveweed1864 is offline Junior Member
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Would this be good for a Tantric HDD 12?
    I want it to go nice and low with authority, but still be able to play quick drum beats like death metal.
    I listen to rap and deathmetal if that helps with the freq response.
    Vehicle is a 2001 Chevy Cavalier Z24 coupe
    Amp is going to be a 2500-3000w (havent bought it yet)
    but it will temporarly on a memphis 500w rms amp
    Box Specs
    15" H x 30" x 12"
    Port 13.5" x 2"
    Gross Volume 2.34ft
    Net Volume 1.64
    Port area per foot 16.49in^2
    Port area 27.00In^2
    Tuning is 35.47 ( torres is being a ***** to get a big port area and low tuning :/ )
    Port length 30In
    Bracing is 45's and threaded rod plus double baffle.
    Picture is below.
    Attached Thumbnails Attached Thumbnails Slot ported enclosure for 12" Tantric HDD-hdd-12-2.jpg
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Re: Slot ported enclosure for 12" Tantric HDD
    Slot ported enclosure for 12" Tantric HDD-hdd-12-3.jpgHere is a top down shot.
    Nutdawg651's Avatar
    Nutdawg651 is offline CarAudio.com Elite
    May 2013
    1,418
    1 Post(s)
    481 Post(s)
    Looks nice good luck
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Thanx man
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Not enough port area at all
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Yea I was told 33 by Tantric but with torres I cannot get it lower than something stupid like 44hz and thats with 50" of port. I dont know what Im doing wrong. Should I make the box bigger it self or how would I get a bigger port area and still be in the low 30's?
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Larger cabinets will allow for shorter ports, but you don't want to go too large if you plan on running that amount of power. And to clarify, it isn't Torres Box Calculator that's causing the port to be so long... it's the laws of physics. ;-)
    Owner, Audio Anarchy, LLC
    2915 Youree Drive, Shreveport, LA
    318-780-6149
    https://www.facebook.com/AudioAnarchyLLC
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    So should I use a bigger enclosure?
    Because I was told by Tantric Sounds to use 2.25cubes with 33" of port area at 22" long and that would put me into the low 30's but in Torres I get 43.3hz. Is that to high or i'm I just tripping?
  9. #9
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    I would go 2.5 cubes and get to 15^2 port per cubic foot which means 37.5^2 overall now im not going to do all the math on it but there's some good guidelines. Just make sure you subtract everything uour at 2.5 or very close to it.
    2002 suburban
  10. #10
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Quote Originally Posted by dbeez View Post
    Ok thank you Dbeez, so after displacement of the bracing and woofer and port , etc it should be 2.5cubes? I'm going to play around with those numbers
  11. #11
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Yes if the the cubic ft changes so does tuning so if you start at 2.5 and then start suntracting your tuning and all are way off.
    2002 suburban
  12. #12
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    I see.. So would this be better? Slot ported enclosure for 12" Tantric HDD-hdd-12-2.5cubes-box.jpg
  13. #13
    Jun 2011
    Wildomar, CA
    13
    3 Post(s)
    Its kinda hard to tell but its 2.51 cubes after displacement and tuned to 34.51 hz with 15.54in^2 per foot for a total of 39.00in^2
  14. #14
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Not sure im not gonna do all the math man.
    2002 suburban
  15. #15
    bbeljefe's Avatar
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by Jesse Cardwell View Post
    Their recommendation would get you a tuning of ~38Hz. In the vehicle it will sound lower so you should wind up ~34-5.
    Bumping the internal volume up to 2.5 cubes with that port will get you down to 32Hz.
    318-780-6149
  1. help with slotted port enclosure for Eclipse SW9152....
    By capthooklv in forum Enclosure Design & Construction Help
    Last Post: 12-06-2010, 09:01 AM
  2. Worklog : Slot ported box for 12" TC-1000
    By Big Dee in forum Enclosure Design & Construction Help
    Last Post: 11-04-2006, 06:58 PM
  3. slot port box for 1-12" hx2
    By RFmustang in forum Enclosure Design & Construction Help
    Last Post: 10-06-2003, 12:53 PM
