Results 1 to 12 of 12
Reload Thread: Enclosure trouble...
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Ok to cut the cost of my system I am building my enclosure completely my self. I have it custom designed to my trunk so it is really hard to explain what it looks like. B/4 any type of dissplacement I have come up with about 6 cubs of space. I am hopeing that with the diss. of the wood, driver, and port it will be closer to 5 cubs. My main problem now is trying to figure out how much port area I need. Using the caculators over at loudspeakers101 I have gotten this info...
    http://www.loudspeakers101.com/VentCal1.htm
    Minimum Diameter = 15.05 inches
    Minimum Area = 177.98 inches
    Length of a side for a square vent = 13.34 inches
    This is all for an 15" sub with 38mm Xmax tuned at 45Hz. What I want to do is either make a plug or and extention to lower the freq. to 28Hz for daily driving. Should I use a 13"X13" inch port or should I make it smaller. I am totaly new to the actual install part of car audio so bear with me. If so, how can I make a plug/extentsion to reach the 28Hz????
    I am open to ideas...
    Your input is appreceated...
    Jon
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Re: Enclosure trouble...
    what is wrong with loudspeakers.com??? Dose it not work right or what???
    What would you all suggest for a port area and plug????
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Yeah it dose, so are there any other reliable calculators out there???
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Hey thanks a ton Jmac, just one last question, the 16x5x15 what is the tuning of that??? 45Hz??? Once agian, thanks man...
    Jon
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Ok still another question... When building the port will I need to make a "turn" (don't know what to call it) so that the port is going alone the back side of the box??? Is that necessary or should I just make the port 15" long and just leave it??? Sorry for the noob questions but I am still getting used to the actualy enclosure design part of car audio... Thanks
    Jon
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Ok I think I understand... So just use the dimentions you gave me earlyer. Hey can't thank you enough, been really bugging me trying to figure this out...
    Thanks a ton!!!!!!!
    Jon
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Shoot, Jmac, I just realized that I can't have the port be 16 inches high. My stock speakers which I want to keep are in the way of the box so I have had to make a lot of little fixes to make my box fit. Let me try and explain, The top of the box is 16" deep but the first 6" (from the front side 6" back) is going to be 18" high then after the 6" I am droping it down to 15" Hope you understand what I am saying.
    Would the freq stay the same as long as the port area stays the same so like I could make it...8x10x15 or would that change the freq???
    Sorry I forgot about this...
    Thanks...
    Jon
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Any one?????? Some one please help me!!!!
  9. #9
    JnEsPappa's Avatar
    JnEsPappa is offline How's Ya Mom n 'Em
    Apr 2004
    Lafayette, LA
    43
    49
    Quote Originally Posted by Jmac
    Doesn't something seem a little fishy, there ?
    NO. What you are noticing is a "correction factor" since you chose Yes for a slot port.
    Read the JL Audio Tutorial page **HERE** for more information on that (read about Lv(eff) ). Bottom line, the loudspeakers 101 calculator IS correct.
  10. #10
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Quote Originally Posted by JnEsPappa
    Ok, Jmac says they are wrong and he says they are right. Who is right???
  11. #11
    JonnyBlaze's Avatar
    JonnyBlaze is offline Member
    May 2004
    Brockton, MA
    48
    wrong. the loudspeaker101 calc dosent take the correction factor in account. not everyone uses the edge of the box for a slot port.
    if you still think they are right, try just changing the height and widths around. leave the same numbers.
    JB
  12. #12
    JnEsPappa's Avatar
    Apr 2004
    Lafayette, LA
    43
    49
    Quote Originally Posted by JonnyBlaze
    JB
    If you have a slot port and change the height you SHOULD get different port lengths because of the end correction factor.
    Try using the 101 calc. and click NO for the "Slot Port" and change the dimensions. Notice the port length doesn't change. That is the way it should be.
    Take it or leave it....just trying to support a well tested, easy to use, time saving applet.
    Later,
    -Mark
  1. Enclosure Vs. Bandpass Enclosure?
    By BigPanch in forum Enclosure Design & Construction Help
    Last Post: 03-07-2007, 12:01 PM
  2. Inverted sub in sealed enclosure?
    By MXJMR in forum Enclosure Design & Construction Help
    Last Post: 02-28-2004, 07:43 PM
  3. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  4. sick a$$ enclosure idea
    By nismboy6986 in forum Enclosure Design & Construction Help
    Last Post: 10-11-2003, 08:17 PM
  5. vented enclosure
    By so n so chicago in forum General Discussion
    Last Post: 08-16-2003, 01:54 AM
