Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: High density fiberboard
  1. #16
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Re: High density fiberboard
    mdf blows..see if you can get arauco in ur area
  2. #17
    timbecht's Avatar
    timbecht is offline Junior Member
    Jul 2013
    United States
    actually i am a woodworker by trade and hdf and mdf is better to build sub boxes with than ply
    reason for this is hdf and mdf is denser and doesn't resonate as much as ply does witch mean the box is deader acts like sound deadner and yes i know this to be true i used to be the head woodworker at my local sound shop and we even tested the material against ply and particle board and mdf won hands down
  3. #18
    des343's Avatar
    des343 is offline CarAudio.com Elite
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Well I use partical board basically the same thing I'm pretty certain works veryy well and a fraction of the price of MDF only thing is makee sure to pre drill holees as it can easily split....ut if done right I have had no issues
  1. FS: 512mb pc133 high density ram (1 stick)
    By CRXBMPN in forum Miscellaneous Classifieds
    Last Post: 10-23-2007, 05:18 PM
  2. High Density paticle board (nova ply)
    By SPL140.2 in forum Enclosure Design & Construction Help
    Last Post: 04-18-2005, 12:00 AM
  3. High Density Fiberboard ??
    By SteveOTheGreat in forum Enclosure Design & Construction Help
    Last Post: 08-25-2003, 08:17 PM
  4. MDF High Density thickness question..
    By quiimari in forum Enclosure Design & Construction Help
    Last Post: 02-18-2003, 10:57 PM
  5. particle board or medium density fiberboard
    By Ganji in forum General Discussion
    Last Post: 05-27-2002, 03:08 PM
