Simple question for everyone, how many cubes for 4 ab xfl 12's walled? will be ran off skar a 4500.1
ok thank you, and if I go with 4 15's how many cubes would i need? Because i just might be able to squeeze out the extra cubes
If you need help, I can do it. We are AB dealers if that helps (12 Gauge Audio), done so many AB boxes, mostly XFL's and HD's.
---------- Post added at 01:06 PM ---------- Previous post was at 01:06 PM ----------
nasty is right though, 8-10 more than likely for ported.
Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
how many cubes would you suggest if i went with 4 xfl 15's? after woofer, port, and bracing displacement? also what is the displacement of a xfl 15? I don't see it on american bass's website
would 3.75 per sub be to small?
No, but I don't know the whole story of specs.
what specs were you referring to?
How big the port is, even what vehicle it is.
Are you going for SPL or daily?
it will be 15 cubes after all displacements, 3 8" aeroports 21" long tuned to 34 hz, ran off a skar 4500.1 at 1 ohm. It will be in a 2006 ford fusion walled off, and it will be a daily ground pounder
Are my calculations off, or should three 8" ports in 15 cubes be around 13" for 34hz?
I got 17.5" for straight 8" ports and 18.5" with aero/flared ports for 34hz. Heres a calculater link.
Products Menu
97 Ram
2 sets Kicker ks650.2 on a
Mmats 2050x
2 American Bass XFL12s(4th order) on
American Bass VFL110.1
Kinetic hc1800
Traded to: WinkyChevelle, Sold to: Outer,Markbuhler007,67bass71, Bought from: Mylows10
Bookmarks
