Results 1 to 3 of 3
Reload Thread: do you need a gasket to invert subs?
    pwr2max's Avatar
    pwr2max is offline Member
    Oct 2002
    Ellicott City, MD
    134
    I am wondering if i need a a gasket or mdf ring between the sub and enclosure if i am going to invert it? Also, do i have to worry about the rubber surround hitting the edges of the box if i follow the manufacturer's reccomended cut-out diameter (i am mounting the subs invertedly to the outside of the box)? thanks.
    InhumanAcura's Avatar
    InhumanAcura is offline 1/3ofTEAM PwNAGE..*****es
    Feb 2004
    South Florida
    8,637
    5 Post(s)
    Re: do you need a gasket to invert subs?
    Wire them the opposite (reverse phase), use the recommended cut-out, and the rubber ring around the driver should be enough gasket.
    pwr2max's Avatar
    Oct 2002
    Ellicott City, MD
    134
    lol that was short...thanks alot
  1. New plan..Treo..need help on these subs
    By 60_cent in forum Subwoofers
    Last Post: 04-20-2006, 02:15 PM
  2. My amp is SUCKING my subs inward!!
    By substance in forum Amplifiers
    Last Post: 04-15-2004, 12:20 AM
  3. Replies: 4
    Last Post: 02-28-2004, 11:07 PM
  4. is this possible, 3 subs, 2 amps, please read.
    By dropt72shortbed in forum Wiring, Electrical and Installation Help
    Last Post: 02-10-2004, 07:39 AM
