Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Reload Thread: burp box daily life
  1. #31
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,840
    71
    2 Post(s)
    2490 Post(s)
    Re: burp box daily life
    Quote Originally Posted by gumby688 View Post
    Well just got back from the first NESPL show in Sanford,ME with the new box. Finished it Thursday night got it in Friday morning and played it for about 5 mins before I went today did a 147.7 and a 147.9 today best with other box was 146.2 need to get a hold of a term lab and do some tweaking all I did between runs today was flip down my visor. I think if I have a day with a meter I could pull a 150 out of the set up.Would love to get a 150 with less then 1000 in my system in total.
    not trying to sound negative but its not that easy. im not saying you wont gain anything, but rule of thumb, """to gain 3 dbs(in probly 95% of cases) it takes double cone area and double power.""" again thats rule of thumb but its a pretty proven statement. you may be able to get a 148.xx with some testing but gaining a whole 2.2 dbs is gonna require more then testing.
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  2. #32
    gumby688's Avatar
    gumby688 is offline CarAudio.com Elite
    Jul 2012
    Fryeburg,ME
    532
    179 Post(s)
    Quote Originally Posted by bgowdy31 View Post
    Last time I spent the day finding the perfect position for my box I picked up 1.7 maybe I already had the box in the sweet spot but I won't know until I test.
    Clarion CX-501 HU
    Rockford Fosgate Punch 400-A4 on
    RF T1 power T152 and T1682 in front doors.
    DDm4 on 2 ZV3 18's
  3. #33
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,840
    71
    2 Post(s)
    2490 Post(s)
    but the closer you get to a 150, the harder it becomes to gain db.... honestly, i just took another look at you equipment. im kinda confused to why your not already doing a 150.... it kind takes me back to maybe the enclosure. Did you do these numbers using the 2 zv3's & PS-4k?
  4. #34
    gumby688's Avatar
    Jul 2012
    Fryeburg,ME
    532
    179 Post(s)
    Yeah and thats why I think I can get it better I found out yesterday I also need more sturdy bracing the 5/8ths rod I was using wasn't enough going to go up to 3/4's and a few 2x4's on the outside of the box.
    Clarion CX-501 HU
    DDm4 on 2 ZV3 18's
  5. #35
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,840
    71
    2 Post(s)
    2490 Post(s)
    i mean again it may be your box thats stopping you, which it could be 1000000 different things lol. i still say for those zv3's like smaller boxes that one seems alittle bit big. i mean thats pretty much 6 cubes probly after displacement each sub and again the sundown site says they do good in cubes net but i may be wrong.
    i know it should be louder then what you did. i did a 147.6db with 1 hdc3 18 in 5.36 cubes with a shotty refurbed planet audio bb2400.1 @ 1 ohm and it only clamped like 500 rms(<on music because thats how the org i compete is setup) when we clamped it, i also had stock 100a alt, 4ga power wire, and 1 extra old lead acid battery in the rear. also that size box for my hdc3 18 is considerably small seeing they call for 6-7 cubes net, and i had little power.
    you can add the bracing, and tweaking the position of the box, also you could resin the inside of the box and see what you can get out it, if that doesnt work id start with a different box, you def have good equipment tho i dont see any need in changing that. i gained like a full db or close just by glassing the inside
  6. #36
    gumby688's Avatar
    Jul 2012
    Fryeburg,ME
    532
    179 Post(s)
    Thanks for the tips the box figures in my sig are wrong now I built a new box its 10.5 cubes tuned at 45 so about 5.25 per sub with 180 sq inches of port.I went and got some glass for the inside of the box today I am going to try that and a few other things.What we need is a forum Termlab maybe get a group of guys together and buy one and share it around like Jockhater2 has done with the DD1. I clamped my popcorn last week @ .5 rising to 2.1 @12.8 volts it did 2936 watts in old box I am going to clamp again tomorrow and see if my box rise changed.
    Clarion CX-501 HU
    DDm4 on 2 ZV3 18's
  7. #37
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,840
    71
    2 Post(s)
    2490 Post(s)
    kew keep the thread updated
  1. single re sx 15 burp box
    By d-REW in forum Enclosure Design & Construction Help
    Last Post: 04-26-2010, 01:06 AM
  2. Designing a burp box
    By area51 in forum Enclosure Design & Construction Help
    Last Post: 12-03-2009, 01:50 AM
  3. burp box design needed will pay $
    By GohillaAudio in forum Enclosure Design & Construction Help
    Last Post: 07-25-2008, 08:42 PM
  4. burp box design needed will pay $
    Last Post: 07-24-2008, 07:23 AM
  5. Tuning for ported box daily/spl
    By Meka in forum Enclosure Design & Construction Help
    Last Post: 02-11-2005, 08:13 PM
