Results 1 to 14 of 14
Reload Thread: 2 subs, do you double the port size?
    JonnyBlaze's Avatar
    JonnyBlaze is offline Member
    May 2004
    Brockton, MA
    48
    a friend of mine just put 2 xtant m412's in serperat sealed boxes. they are just under 1 cubic foot each. hes pushing them with a punch 360. it sounds decent the way it is but i want to build him a ported box hoping it will be louder.
    the spec sheet for the speaker recomends a 2.50cf box with a 4"x8.75" port and it says that would be tuned to 37hz.
    for 2 subs, i would make the box 5 cubic feet but what do i do with the port dimension? does the length double? does the diameter double?
    i probably was going to use a rectangular port, which would be 1.5"x8.38" if that matters.
    there are also specs for a bigger box (3cu each) with a lower tuning frequency (35hz). would i be better off using the biggest box they say?
    thanks alot
    JB
    Casserole's Avatar
    Casserole is offline Member
    Jan 2004
    KS
    122
    Re: 2 subs, do you double the port size?
    http://www.jlaudio.com/tutorials/ports/index.html
    "Notice that Method 1 produces the same port length as did our single 4" diamter port as it should (after all, we have the same total port cross-sectional area which this school of thought proclaims is correct!). But the first method is incorrect because it neglects the fricitional losses encountered by using many smaller ports--there is a higher port wall surface area to cross-sectional area ratio which raises the total amount of frictional losses in the ports and thus shifts the tuning!"
    EDIT: just realized it was two subs vs two ports. so what i just posted may have nothing to do with this situation.
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    use the JL Audio equation with the increased box volume and the same tuning frequency and that should tell you
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
    JonnyBlaze's Avatar
    May 2004
    Brockton, MA
    48
    does anyone have a clue how to get that equation into excel? and where does the number of drivers come into play?
    JB
    JnEsPappa's Avatar
    JnEsPappa is offline How's Ya Mom n 'Em
    Apr 2004
    Lafayette, LA
    43
    49
    Quote Originally Posted by JonnyBlaze
    JB
    =.159*((AV*(1.84*10^8))/(VB*(LV + .823(AV^2))))
    Instead of AV, type in the cell where AV is located and do the same for VB and LV
    The parentheses are important to get right.
    Benny212's Avatar
    Benny212 is offline Member
    Dec 2003
    Loveland Colorado
    126
    JB
    number of drivers doesn't come into play with that formula. Only thing that more drivers would change is the optimum port area, because more air being moved means it might be a good idea to go with a larger port
    JonnyBlaze's Avatar
    May 2004
    Brockton, MA
    48
    Quote Originally Posted by JnEsPappa
    thanks alot.
    this is my first ported box design and theres alot to learn. i want to get it right the first time.
    i think im going to port it high, maybe around 45hz and make a plug that will change it to 27hz. ill post my designs once i get it drawn up.
    JB
    edit: its my second ported box actually. my first was a 5cubic foot for my stroker, but i wouldnt bet i did it correctly
    Omarvelous's Avatar
    Omarvelous is offline CarAudio.com Elite
    Jan 2004
    Queens, NY
    28
    1,371
    I'm not seeing how you implemented the Square Roots in the equation.
    I'm sure excel can do Square root.
    First get the Square Root of AV then plug it in here * <- (indicated by asterik *)
    =((AV*(1.84*10^8))/(VB*(LV + .823(AV*))))
    Then take the value from the equation above and Square Root it wid a Calculator then x that by .159
    Unless i'm missing something...
    Also might wanna check my thread on the Swappable port - might have a method that will work for u
    NOW
    2007 Maxima SE
    -HU: Stock
    -Goodies: 15" MX + Orion 2500D = sexAYYY
    Quote Originally Posted by bimma85
    Guess Im an internet nobody , but guess what; Im a real life somebody .
  9. #9
    Omarvelous's Avatar
    Jan 2004
    Queens, NY
    28
    1,371
    Quote Originally Posted by Jmac
    Fb = 0.159*[Av*1.84*10^8/Vb/(Lv+0.823*Av^0.5)]^0.5
    I think ... It's late ...
    Yes ^.5 will work also! That is better!
    NOW
    2007 Maxima SE
    -HU: Stock
  10. #10
    JonnyBlaze's Avatar
    May 2004
    Brockton, MA
    48
    thanks for the help guys. but is there a way to modify the equation so instead of giving you the tuning frequency (Fb), it gives the port length (Lv)?
    as it is i have to give the length to get the frequency.
    and i used to think i was good at math
    thanks again
    JB
  11. #11
    Omarvelous's Avatar
    Jan 2004
    Queens, NY
    28
    1,371
    Well.... since you are the one who is giving the LV in the formula i would imagine you already have the length of the LV.
    I know what you mean by flipping it, but if you have LV set to a cell, you could jus keep changing the length until you get your measure.
    But....
    I guess you could ^2 the equation and then work from there. I'm not attempting it however! lol
    NOW
    2007 Maxima SE
    -HU: Stock
  12. #12
    Acidburn's Avatar
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    i got: Lv = ((4651704 * Av)/(Fb^2 * Vb)) - 0.823 * Av^.5
    MdOiDcEtRaAtToOrR
  13. #13
    Acidburn's Avatar
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    oh well, just plug it back into the original to make sure whatever you get works
    MdOiDcEtRaAtToOrR
  14. #14
    JnEsPappa's Avatar
    Apr 2004
    Lafayette, LA
    43
    49
    Thanks for poiting out the sq. root guys.
    =.159*(((AV*(1.84*10^8))/(VB*(LV + .823*(AV^.5))))^.5)
    You can never have enough parentheses I say. That way there is no confusion over the rules of order.
  1. Help with port dimensions
    By Farside in forum Enclosure Design & Construction Help
    Last Post: 07-10-2004, 01:49 PM
  2. Looking for new subs
    By Dubb93 in forum Subwoofers
    Last Post: 04-27-2004, 03:36 PM
  3. Replies: 4
    Last Post: 02-28-2004, 11:07 PM
  4. Replies: 2
    Last Post: 01-13-2004, 12:30 AM
  5. l7 vs w7
    By the_flatlander in forum General Discussion
    Last Post: 12-11-2003, 07:22 PM
